2012 cross country tour /electrical problems - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 10-08-2012, 11:08 PM Thread Starter
bcflyguy's Avatar
Send a message via MSN to bcflyguy
Default 2012 cross country tour /electrical problems
Hi all,
I have a 2012 cct that looses ALL POWER intermittantly. I pull over to side of road and re set key to off then the on position, reboot kill switch from on to off and back on , hit starter butter and right away it starts and will be ok for 8/1,000 miles then will loose power again. Checked battery connections and battery connection. All good. Dealer says possible defective main relay. Still on warranty. Any suggestions?
Thank You
bcflyguy aka Neil
Kelowna British columbia Canada
1 2012 cross country tour arlin ness big honkers/ fuel controler/air mod, Bag rails, Ostrich 2 up custom seat, Sheepskin seat cover, trunk rack. Bag locks
2 2013 cross country tour . Trunk removed. ness honkers lloydz air box, bag rails Rich's custom gel/ ostrich seat .Bag locks. chrome pass boards. Ignition relocate.Kury mirrors,
bcflyguy is offline
post #2 of 8 (permalink) Old 10-09-2012, 06:45 AM
Lostintexas's Avatar
Do you have a relay ordered? Poor connections are usually just a start and go, no reset of anything required. However,,,,,,,,Did you check both ends of the battery cables? With a wrench? A bad ground can do the same thing. Take it off, see if there is paint, gunk or junk hendering the connection. A grab and shake can be deceiving.
These kind of things can be a nightmare to track, especially with multiple ground points like I am sure this bike has because of the remote battery location.
Good luck.
Lostintexas is offline
post #3 of 8 (permalink) Old 10-09-2012, 11:11 AM
you can get relay at auto parts store Radio shack
pull out old one plug in new one
Coast is low
Are you blipping the throttle thats a no no
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #4 of 8 (permalink) Old 10-09-2012, 09:38 PM Thread Starter
bcflyguy's Avatar
Thanks for the imput lostintexas. Today,the dealer found that the main breaker fell apart in his hand as he was making his final check. He changed the breaker and we'll see if that solves the problem. Seems to be running much better
Thanks bcflyguy aka Neil
bcflyguy is offline
post #5 of 8 (permalink) Old 10-09-2012, 09:41 PM Thread Starter
bcflyguy's Avatar
Hi Visionjohnny,
What does blipping the throttle mean? The problem that was found today was that the main breaker fell apart when being checked. Must have had a rock hit it or something.
Still want to find out about blipping
Thanks bcflyguy
bcflyguy is offline
post #6 of 8 (permalink) Old 10-10-2012, 11:31 AM
If I say this right. When you shift gears you give it a little gas so the gears mesh easier. Giving it the gas is called blipping. Or when you sitting at the stop light you hear some keep giving the bike quick shots of gas thats blipping. Our Vic don't like it cause the FI don't react that fast cause of our Idle Air Valve . So if you do it wrong you can kill the motor.
I'm sure some one can explain it better. Happy your up an running.
No Hillary Clinton
post #7 of 8 (permalink) Old 12-01-2012, 06:43 AM
Pop
Did the main breaker thing work out?
There's a bunch of ways for the bike to quit and then start right back up but a "main breaker" falling apart is a new one on me. Possible, just odd.
Hey admins, can this thread get relocated to somewhere else? I'm interested if this is a one time issue or what. The riders lounge is good for changing the world but motorcycle repair doesn't get much press here.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #8 of 8 (permalink) Old 12-01-2012, 10:00 AM
jbasile's Avatar
That wouldn't kill his electrical power though. I'm thinking the scoot is fixed now.
jbasile is offline
You may post new threads
You may post replies
