Help pls - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 10-30-2012, 09:31 PM Thread Starter
Default Help pls
I did some changes on my Vic... now i have aircleaner mod and shot gun exhaust...i also have a Vic stage 1 code card.. WHO DOES THE CODE UPDATE IN MIAMI ?? And how much are we talking ...also, do i need it ????
HELP
2007 VEGAS ( BIG BALLS )
www.houseofthunderusa.com
DAREDEVIL is offline
post #2 of 4 (permalink) Old 11-01-2012, 08:01 AM
browneye's Avatar
What tune are you running? Stock?
Did you make your own air cleaner? And I am guessing you finished your rear tire swap earlier this year.
2008 Vegas Premiumthumb up
1978 Harley FXE B@$TERD Shovel:mad:
browneye is offline
post #3 of 4 (permalink) Old 11-01-2012, 08:09 AM Thread Starter
Tire swap just done last week, air cleaner k&n nothing fancy, tune... I believe stage 2 but exhaust says stage 1 needed and came with flash card. Gone get it done today!
post #4 of 4 (permalink) Old 11-09-2012, 04:17 PM
theteese's Avatar
DD,
I had alot of popping, sluggish throttle response etc after Stage 1 upgrade so i took the bike and got it dyno'd.
I see Lloyds reckon i can kill the popping a bit better and gain more power if i add more fuel to it ( 13.0.1 ) due to the optimum A/F ration for our bikes is 14.7.1 ( They don't mind running a little lean ) but i asked the Dyno dude to run my A/F ratio around the 13.8.1. This mean't i added a little bit more fuel but not a lot and i wanted more mid range grunt for over taking those GRANNY drivers on the highway.
Torque from 1800 - 4500 is much better and popping is a little less as it's hard to stop it with a closed loop engine.
As most people have stated, All bikes are different so by getting a personalized dyno tune then you get what you want.
I hope this helps yeh m8.
Cheers
AL
Vegapot - 2009 Vegas Lo Custom, A Bitsa of an Exhaust, Mustang Solo Seat, Jackpot 250mm Rear End, Stage I Upgrade, Highball Mini Apes, Alen Ness Bullet Turn Signals, Power Commander V, Luv Ridin it.
theteese is offline
