2003 Vegas - power commander questions - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 11-02-2012, 12:43 PM Thread Starter
so-crates's Avatar
Hey folks. Thanks for reading my post...
I am the proud new owner of a used 2003 Victory Vegas. I love the thing - except for the fact that it runs like crap when trying to hold a steady rate of speed, with it popping and backfiring all over the place...
I bought the bike used with 14K on it. It has the Ness Big Sucker K&N air filter kit, and straight pipes. But, it doesnt have a POwer Commander on it...and I know this is the problem... So now for my questions:
I have done some research, and I am aware that the part number for teh Power Commander is 909-411. I am wondering if anyone has ever attempted to use a PCIII from the same year's V92C model?? It has a similar part number - 904-411. I was wondering if I would be able to use that one (as I can find it far cheaper than the Vegas specific model...)
Ive also heard mentioned on this site a company called LLoyd's and their fuel controllers. Are they easy to use plug&play like Dynojet PCIII is??
Last question - lets say I go with a PCIII - does anyone have a map they can share with me for the K&N and straight pipes?? Because I didnt find one on the Dynojet site...
Any assistance is appreciated!
so-crates is offline
post #2 of 12 (permalink) Old 11-05-2012, 03:03 PM Thread Starter
so-crates's Avatar
Uh, bumpski?? ANYONE??
I am also wondering about the Ness Big Shot fuel tuners. Are they as easy to use as the Power Commander is?? Do they have maps already set up on the website. etc??
Anyone?!?!?!
post #3 of 12 (permalink) Old 11-05-2012, 03:24 PM
CrossRoads's Avatar
Before you rip the Power Commander out, let's try to eliminate the most obvious suspect for your symptom. When was the last time you've cleaned the throttle bodies?
CrossRoads is offline
post #4 of 12 (permalink) Old 11-05-2012, 04:58 PM
half_crazy's Avatar
Sounds like a fuel pressure issue. Check the fuel pressure.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #5 of 12 (permalink) Old 11-05-2012, 05:09 PM Thread Starter
so-crates's Avatar
Mr. Crossroads - while I greatly appreciate your response, I thought I had already found the most obvious source of my problem - there IS NO POWER COMMANDER on it!
My original post was asking if the PCIII from a V92C will fit - it is part number 904-411, whereas the PCIII for a Vegas is 909-411 - I am wondering if it will work or not...Im thinking the wiring harness is probably too short.
My second post was asking about the Ness Big Shot controlers, wondering if they are as easy to use as the PCIII, which I have experience with... they are a llittle cheaper, so I was considering one of those instead of the PCIII.
Im down with cleaning the throttle bodies too though - where would I find them? Im guessing its remove the tank and the airbox and finding them under that??
Thank you again.
post #6 of 12 (permalink) Old 11-05-2012, 07:14 PM
CrossRoads's Avatar
My bad - I must have misread your post.
That's right. Take a peak in the service manual too if need be (see this thread to download yours). I would clean them before doing any adjustments, additions, etc.
post #7 of 12 (permalink) Old 11-06-2012, 11:27 AM
Sounds more like a vacuum leak or cracked throttle body rubbers to
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #8 of 12 (permalink) Old 11-10-2012, 10:38 PM
theteese's Avatar
Hi So-Crates,
If u want some advice ( IMO ) then dont waste your money as they are really for modified engines ( Cams etc )
You would be better off going to a dyno and adjusting your throttle response, adjusting the A/F ratio to 13.8.1 - 14.0.1 and moving your Tourque to 1800 - 4500.
$200 - $300 ( Someone who knows what they are doing... 2- 2 1/2 hrs on the tune ).
I think you will be very happy with that.
Cheers
AL
Vegapot - 2009 Vegas Lo Custom, A Bitsa of an Exhaust, Mustang Solo Seat, Jackpot 250mm Rear End, Stage I Upgrade, Highball Mini Apes, Alen Ness Bullet Turn Signals, Power Commander V, Luv Ridin it.
theteese is offline
post #9 of 12 (permalink) Old 11-20-2012, 04:47 PM Thread Starter
so-crates's Avatar
Well, I spent $177.47 on the Wiseco fuel tuner and installed it this weekend. Very simple to install - take off the tank, remove the rear cylinder FI harness, plug in new harness and plug old harness into new one. Same on front cylinder, only instead of directly onto the injector, it hooks up to a pigtail connector and leads to the injector. Plug in, attach to negative terminal on the battery, velcro to inside of side cover and I was done - less than one hour to take off the tank, install and replace the tank. Bike ran really good - seems to have cured the surging and stumbling at constant throttle, and doesnt sound quite as grumbly when letting off the gas. Has a little hiccup when going full throttle - just needs another small adjustment... Will do it next time I ride it!
If anyone is experiencing similar problems, do NOT pay $299+ for a fuel tuner. I got mine off Amazon shipped for $177!
2003 Vegas - straight pipes, Big Sucker air filter kit, black powder coated everything - foot controls, handlebars, clutch and brake housing, fork lowers, luggage rack, wheels, digital speedo with powder coated housing. Relocated key switch, red plug wires. Mustang solo seat. LED ring blinkers in front. Black DEI pipe wrap.
post #10 of 12 (permalink) Old 01-28-2013, 06:17 PM
Tarzan's Avatar
These guys are already giving you good advice. I agree with most of them. You should not need a controller.Most probably, either your throttle-bodies are dirty, you have cracked throttle-body adapters, TPS not set right, Map isn't right, vacuum leak, or a variation of a couple things. Putting a controller on before making sure everything else is right can just mask a problem temporarily.
I know on my Kingpin, I have to clean the throttle-bodies every 7-8,000 miles.
'14 Ness XC
Tarzan is offline
