I'm done ..rear spark plug fillers - Page 2 - Victory Forums - Victory Motorcycle Forum
 13Likes
post #11 of 17 (permalink) Old 07-16-2019, 06:45 AM
gamewarden's Avatar
I have had mine on for years never a problem, yet|||
RICZ and roadcouch like this.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #12 of 17 (permalink) Old 07-16-2019, 08:51 AM
Originally Posted by rojo154 View Post
Which one did you lose, or was it both? Yea, a lot of stuff is made in China no matter who's name is on it or what you pay. I would not be surprised that they all are made there.
Just the rear one's.
2015 Victory XC; Vance & Hines High Output slip on, PCV, WindVest,Trunk, Arlen Ness floorboards/heel toe shift/brake arm
IslanderX is offline
post #13 of 17 (permalink) Old 07-16-2019, 01:45 PM
My bike seems like the suspension is a lot stiffer than my 04 was. I got to wonder if this has something to do with it.
I was thinking if a small piece of rubber under the disc, or maybe an o-ring would help at all.
You possibly got a good idea there. Maybe put a screw on the back of the filler to attach an insulated wire looped around the plug wire. Or maybe a zip tie?? Wish I thought of this myself after losing the first one. I will never know unless I some how find one for next to nothing.
Wire loop around plug wire?
Will cause one hell of a short if it ever wears threw the boot
post #14 of 17 (permalink) Old 07-16-2019, 05:07 PM
Well he's got rears. Sounds like you two can work something out.
post #15 of 17 (permalink) Old 07-23-2019, 08:08 PM
I've had the Kuryakyn set for a couple of years now. When mounted, mine look exactly like the picture Ricz posted. I see no way for these to just fall off as they're kind of a pain to remove when I annually replace the spark plugs. The one remaining cover originally posted is clearly not mounted correctly as there's way too much space under the cover as mounted. And yes, the original Kuryakyn set I bought had a Made In China sticker on the packaging.
RICZ and Motorbikerx like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #16 of 17 (permalink) Old 07-24-2019, 12:51 AM Thread Starter
rojo154's Avatar
Yea, and one would have thought that rear would have fell out but it didn't. Like I said I had them on my other Kingpin for some time and never a problem. I actually found a front to replace the lost one. When I get it the safety wires will be going on both fore sure. ..And I would almost bet they won't ever come loose. If that's what it will take!
I got some other recent pics that I'm gonna check to see if I had that back one in right or off by a fin. I removed it after the loss of front and believe I shoved it back in to take the pic. I don't think the foot would have even reached the motor to tighten it and would have fell out .(foot itself) ... found a pic, they are in correct..... OK , can't figure out how to upload the pic and it is 2:30 am I give up
Chattanooga Mark likes this.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #17 of 17 (permalink) Old 08-02-2019, 06:57 PM
roadcouch's Avatar
Well both of mine are gone today! WTF they lasted 2500 miles. 300 miles today. Lost them both sometime in the middle of the day. They were the cheap ones on eBay. My guess the plastic pressure point below maybe shrinks or melts just enough to let the them fall off.
I was thinking about putting a dot of sandpaper under the pressure point. What have you guys done to keep them on?
2013 xc sunset red blacked out
Loydz air filter
Loydz cams
Loydz timing wheel
Big honkers
Loydz 1/4 throttle ring
PC 5
Evil Eyz headlamp bezel
Victory hid
Klockwerks flip windshield
Ness grips
roadcouch is offline
