Lowering kit for VV - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 09-01-2014, 06:24 AM Thread Starter
Default Lowering kit for VV
Hi All, tried to search for this answer, but did not find anything Vision specific... I am trying to solve for my passenger, who is a pretty tall girl 5'10", is sitting to high up and getting a lot of wind. We got on a Goldwing and she liked that setup much better, but I do not want a car on too wheel In searching I came across a post suggesting two things: shave seat foam; install rear lowering kit. Can someone share experience with lowering a Vision? Also, any other ideas beside these two?
afarbman is offline
post #2 of 9 (permalink) Old 09-01-2014, 08:20 AM
spanknut24's Avatar
see if there is a taller windshield for it.my wife is around same height and had no problem with wind when i had he wind shield raised all the way.former vision owner have a kingpin now due to accident.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #3 of 9 (permalink) Old 09-01-2014, 09:58 AM
Tims_04V92TC's Avatar
Welcome to the forums!
Lowering is not going to resolve your issue. The vision does ride higher for the pinion but before I shaved the seat I would look at a 7jurock or Klockwerks flip windscreen. With the vision having the electric windscreen you could go up to a 19" flip but only push it all the way up when she is on the back. Otherwise you could roll it down and keep it just under where your stock rides. The flip,does have a little distortion on the road when you look directly through it but I think you could adjust height to not have it in direct line of sight. There are other posts on the flip shields by vision riders but here is the one I wrote up.
If you have more questions post them and will. Try to answer.
Saf,e riding.
Tim
https://www.victoryforums.com/showthr...lip+windshield
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #4 of 9 (permalink) Old 09-01-2014, 10:33 AM
Look for the Ness seat and it will lower you and maybe her. Not cheap.
New wind shield will do the trick you'll want clear one cause at night its really hard to see threw a tinted one.
They have one thats 22" tall for $150 bucks
http://www.ceebaileys.com/victory/victory_ws.html
lowering the bike will not change the air flow for her
post #5 of 9 (permalink) Old 09-01-2014, 12:45 PM
Oldman47's Avatar
The pillion on a Vision sits about 5 or 6 inches higher than the driver. That is reality. What you can do about it is easy. If you can tolerate looking through a windshield you can get a taller one as Tims suggested. I have had great luck working with Cee Baileys in the past but have not tried them with my Vision. If you go with an after market windshield you need to recognize that a flip type really does not do much for a passenger. When I put a Euro-flip on my HD my wife's response was along the lines of why did I bother. It did nothing for her on the back. I felt the change big time but it really only worked for the driver, not the passenger.
Oldman47 is offline
post #6 of 9 (permalink) Old 09-01-2014, 09:32 PM
ndabunka's Avatar
use the button on the dash to raise th windscreen
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #7 of 9 (permalink) Old 10-04-2014, 01:15 PM
eotsis1's Avatar
http://www.conquestcustoms.com/frontloweringkit-1.aspx
Here is a 1" lowering kit for the vision. They also have a 2-3" lowering kit but you have to shave some of the bottom of the saddlebags for corning clearance.
http://www.conquestcustoms.com/vision23slampackage.aspx
1 Corinthians 15:57 But thanks be to God! He gives us the victory through our Lord Jesus Christ.
2009 Vision... Lloyd cams, pipes, timing wheel +4, power commander V, gps, xm, centramatics, DARKSIDE
eotsis1 is offline
post #8 of 9 (permalink) Old 10-04-2014, 06:06 PM
Do you have the trunk on? What doe your windshield measure now. From center to top.
Lowering the bike the air will still be down there
I see he has not bothered to come back and make a statement
post #9 of 9 (permalink) Old 10-22-2014, 08:26 PM
mikebna's Avatar
Make sure the kickstand is at least 1" shorter if you lower it, or it will end up using the tip over protectors more than you need to-
2013 Arlen Ness Vision
L1 Exhaust, PC5, Top Ness Air Filter, Vision Fog Lights, Lighted Victory Trunk Emblem, Highway Pegs, Lighted Victory Heritage Badges, Drivers Backrest, Passenger Arm Rests, Lots of extra chrome pieces added...
mikebna is offline
