30k service on 2010 vision fork oil chg - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 27 (permalink) Old 11-19-2014, 10:48 PM Thread Starter
New Member
rkortan's Avatar
Smile 30k service on 2010 vision fork oil chg
I have completed the 30k service on my 2010 vision except for the front end service that was done at the dealer in Reno at 15k. My question is do I really need to do the front end/ forks again now or/ and how long can I wait. I have the service manual and don't think I want to try changing the oil myself. I think the quote from the dealer was in the 300 dollar range to take the whole front end apart. Any advice would be appreciated. Thx, Bob.
rkortan is offline
post #2 of 27 (permalink) Old 11-19-2014, 11:25 PM
Motorbikerx's Avatar
personally I think Ma Vic likes her bikes over-serviced.
I'm probably not the only one.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 27 (permalink) Old 11-20-2014, 10:37 AM
rkortan
if you had it done at 15K I would wait till you had 75K on it before doing it again.
Victory has some ridicules intervals for matinées
I think
post #4 of 27 (permalink) Old 11-21-2014, 03:50 PM
kevinx's Avatar
Lots of bad advice to be found. Forks are subject to amazing amounts of abuse, and only work as well as they are serviced. Remember a motorcycle has 2 wheels, and not only does the suspension effect the way it rides. The main job is to keep the tires on the road. Nothing better then a panic stop, ABS kicks in, and you start dribbling the tire like a basketball. The fluid degrades slowly, and you may not notice it as much, but the difference is huge. Fork oil suffers from heat, friction, and an amazing amount of shear. As it wears it becomes thinner, and rate of flow changes through the regulator holes, in the cartridge. Shearing causes varnish to build up, and that makes sliding parts sticky. Just because you can't SEE the effects; like with dirty oil on a stick. It does not mean you can ignore them.
Yes 15K might be overkill for a easy rider, but not for an aggressive rider. Even an easy rider should go no more then 20K.....It's not like your life depends on how well you maintain your bike......Oh yea....IT DOES!!!
NOEMTZ likes this.
kevinx is offline
post #5 of 27 (permalink) Old 11-21-2014, 06:07 PM
catroadman's Avatar
Would the factory oil be best?
2011 X-country
catroadman is offline
post #6 of 27 (permalink) Old 11-21-2014, 06:28 PM
ByteN2it's Avatar
I've been doing the fork fluid when I replace the front tire-works out just about right and your already half way there. I do prefer the full synthetic fork fluid-I've been using Silkolene the last couple times and also had good results with Red Line, the stock factory oil seemed like water to me when it got real hot out and the forks would dive more than I like under heavy breaking/scrubbing off speed going into corners-much improved with the 10W full synthetic on those hot days.
ByteN2it is offline
post #7 of 27 (permalink) Old 11-21-2014, 07:52 PM
kevinx's Avatar
All good advice in this one
kevinx is offline
post #8 of 27 (permalink) Old 11-22-2014, 12:56 AM
@kevinx
ok mate what exactly is entailed in me servicing the forks in my Vegas?
I got access to a bike lift now and improving the rear with a Progressive shock has shown up the front forks shortcomings.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 27 (permalink) Old 11-22-2014, 06:02 AM
kevinx's Avatar
Originally Posted by Motorbikerx View Post
@kevinx
Basic service is pulling legs. Dropping the springs. Flushing with clean fluid. Filling with clean fluid. Note that Vic uses a liquid measurement as a STARTING POINT then you use a measured height from the top of the collapsed tube.
kevinx is offline
post #10 of 27 (permalink) Old 11-22-2014, 07:55 AM Thread Starter
New Member
rkortan's Avatar
Thx for the comments. Looks like I will be servicing the forks about every 25k.
rkortan is offline
