Lloydz Adjustable Intake System - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 01-02-2015, 09:41 PM Thread Starter
Oldman47's Avatar
Default Lloydz Adjustable Intake System
Does anyone have experience with this system? Rylan of the Vic Shop recommended it to me last fall when I was getting the Lloydz top air filter installed and getting a tune using a new PCV. The Lloydz site says it will give you nice torque numbers but he does a CYA and says it will do that in combination with other things. I am interested in knowing how this device stands up on its own. Many of us can relate how a timing wheel , as the only mod, affects performance. Being a Vision only performance part I suspect there is not much experience out there but now I am trying to decide whether to drop about $400 to get this part and a tune to go with it. I am still running stock exhaust and stock cams so the combination stuff on Lloydz site really does not apply to me.
Any help out there?
Oldman47 is offline
post #2 of 7 (permalink) Old 01-03-2015, 12:02 PM
Really what your saying is you want to go back to Rylan. Before you know it you'll be doing cams. Having power is addictive drug for sure.
Good Luck
post #3 of 7 (permalink) Old 01-03-2015, 08:30 PM Thread Starter
Oldman47's Avatar
I really wish it was that simple VJ. I am very interested in getting the bike to run more efficiently at lower engine speeds. I never feel the power I have now except on freeway on ramps so more would not mean much when I am out riding.
Oldman47 is offline
post #4 of 7 (permalink) Old 01-16-2015, 06:58 PM
The intake works. Rylan has dyno sheets from my Vision before and after the adjustable intake. Big difference in low end torque. Now that I have the 116 he changed the insert to bigger ones. I think there is 3 different sizes. One for no cams, 1 for cams and 1 for big bore with cams.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #5 of 7 (permalink) Old 03-12-2015, 08:53 PM
Tims_04V92TC's Avatar
I have a timing wheel, the intake, both top and front filters, PCV and a tune. My take is the PCV and tune were crucial and the intake has really brought up the low end. As for your stock exhaust, Lloyd said they were decent pipes especially if you wanted more torque. He said the Venturi effect of the intake was worth it and I have no regrets. May go back for cams but glad I did the intake.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #6 of 7 (permalink) Old 03-16-2015, 01:17 PM Thread Starter
Oldman47's Avatar
Thanks guys. This is what I wanted to know. No way am I interested in cams right now. I view those as top end enhancement and I do all of my driving under 4000 RPM.
Oldman47 is offline
post #7 of 7 (permalink) Old 03-16-2015, 02:30 PM
Default simple fuel controller
on my 13 hammer i did intake, exhaust, timing wheel @ +6 with premium 93 oct fuel + a dobeck AFR+ aka LLoydz AFR Gen IV. the VFC III would prolly serve you as well. i enjoy the added go on the low end but would never open up a perfectly assembled engine, the Ham has more balls than I already. some go for the gusto, if thats your thing + you got the $$$$ go to it. its just not necessary for most riders, your bike your choice!!!
rodhotter is offline
