Front Speaker Replacement on 2012 Vision - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 06-07-2012, 05:36 PM Thread Starter
New Member
Default Front Speaker Replacement on 2012 Vision
Would love some detailed help on how to replace the front speakers on my 2012 Vision. I got the front shrould off that also has the antenna conection and 2 fasteners right behind the mirrors but still could not get the bezel off. Please help and be as detailed as possible. Thanks so much
kp65 is offline
post #2 of 9 (permalink) Old 06-07-2012, 07:57 PM
You've only just begun. The instrument bezel needs to be lifted left and right edges with preferably aplastic putty knife. Then left straight out.
There are two more screws for the mirrors. One on each side on the bottom of the mirror. When you've undone the bottom screw, hold the mirror so it doesn't fall out.
There are two screws behind each mirror and one more under where the bezel was for a total of three, each side. Then pull that whole panel straight out to release tabs.
You can now replace the speaker.
Take your time....have fun!!
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #3 of 9 (permalink) Old 06-08-2012, 10:45 AM
As long as your doing speakers you should think about a better antenna and even a amp.
post #4 of 9 (permalink) Old 06-08-2012, 10:58 AM
Say you will need a good flask light a magnet and a short 10mm socket
post #5 of 9 (permalink) Old 06-08-2012, 04:13 PM
Personally, I'ld like to see someone come up with speaker grills to replace the mirrors. The wiring is already there and I think the sound would be great. I don't find the dash mirrors all that useful.
cams/D&D
2009 Ness Vision
116 Big Bore
Blueline is offline
post #6 of 9 (permalink) Old 06-09-2012, 07:18 AM Thread Starter
New Member
Thanks so much for the help. Good advice and all went smooth
kp65 is offline
post #7 of 9 (permalink) Old 06-09-2012, 09:43 PM
Thunderduck's Avatar
The mirrors are great if all you want to see is your hands
Max
2011 Vision Tour Crimson Red, bag rails, iPod hookup, heel to toe shifter, Joe Florida LED's, Lowers, extra top mirrors, Utopia Backrest
Thunderduck is offline
post #8 of 9 (permalink) Old 06-10-2012, 12:34 PM
Don't you have the XC controls so you could put mirrors on your controls if you wanted.
post #9 of 9 (permalink) Old 06-10-2012, 01:01 PM
I have a Vision Tour, I bought some other mirrors from Auto Barn that mount on top of the other ones. The only problem with them is they do not stay adjusted. But what the heck they were only $40.00, the only reason they were that cheap is they did not say for motorcycles.
Max
