Replacement Grips - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 04-18-2015, 04:45 PM Thread Starter
butterfly182310's Avatar
Default Replacement Grips
The heated grips on my '08 are deteriorating. The rubber is feeling like a bad batch of gummy bears. If I don't wear gloves, my palms look like I am wearing gloves. Is there an aftermarket "heated" replacement grip available anywhere, or do I simply have to do an OEM replacement?
butterfly182310 is offline
post #2 of 7 (permalink) Old 04-18-2015, 06:10 PM
look on the net for grip puppies. Good feel don't leave your hands black or tacky. You can feel the heat just fine. They slid over your grips.
If you have a goldwing shop around stop in they usually have them
post #3 of 7 (permalink) Old 04-18-2015, 11:57 PM
v-rodder's Avatar
Heat Demons and Avon grips both are options. Actually heat demons are used in the Avon grips. However they won't work with the victory stock switch since they offer more heat settings than low/high. You can mount their switch on the vision's dash but it looks like ass. For a clean look, OEM is still the best.
v-rodder is offline
post #4 of 7 (permalink) Old 04-19-2015, 12:02 AM
Tri-J's Avatar
Love the Puppies!
__________________
'13 Vision
Tri-J is offline
post #5 of 7 (permalink) Old 04-19-2015, 08:38 PM
lstayner's Avatar
Originally Posted by Tri-J View Post
Attachment 130513
Love the Puppies!
+1 on the grip puppies. Don't use soap to put them on though like the instructions say. I use hairspray. It is 10 times easier to slide the grips on. If you ride a lot, you will need to replace them about once a year. Still cheaper than a new set of grips.
ATGATT because walking away in disgust is better than riding away in an ambulance.
Never get to busy making a living that you forget to make a life.
Larry
2011 Pearl White Vision 88,000 smiles
lstayner is offline
post #6 of 7 (permalink) Old 04-19-2015, 08:45 PM
TheMike's Avatar
I have the Avon heated on mine. Since I have a Ness bike it didn't come with any. 4 levels of heat and the grips are many to choose from. I got mine through Witchdoctors. The controller is made for handle bar mount which our Visions won't take. WD shaves the mount for a flat surface mounting of your choice. Mine is on my center console.
Waaaaay better than stock heat (Wife's XCT has them so I know). Sorry no pic of the controller mounted. Mine is under my GPS on the center console which you can visualize in the last pic. It wasn't mounted yet.
Original
Heated
2012 #20 NESS Vision DARKSIDE BABY!
Stage 1 w/D&D pipes + lots of Victory add ons. PC-V w/AT, Lloyd's intake, filter, ATS, & Variable Clutch.
2013 Bushtec Entourage in matching Ness color and graphics - See the PAINTED TO MATCH process
Wife rides a 2016 Gunner
LONGMONT COLORADO
TheMike is offline
post #7 of 7 (permalink) Old 04-22-2015, 10:11 PM
v-rodder's Avatar
Spoke to Avon on Monday. They are working on heated grips that work with Victorys that don't require the modified HD controller. I did not ask about the timeframe. I just needed a regular set of grips. I would call Avongrips.com and ask for more details.
Jim
2011 Victory Vision, PCV, Ness Honkers, Timing Wheel, Both Ness Filters (front, top), 1/4" throttle ring, LLoyds VM1 Cams & Adjustable Intake, tuning by Mr Kyle himself. 116 hp and 121 tq.
v-rodder is offline
