Vision 2015 upgrades - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 11 (permalink) Old 02-12-2016, 10:01 PM Thread Starter
BP6666VR's Avatar
Default Vision 2015 upgrades
Hi Vision owners,
I need your advice, a friend has a 2015 Vision, complete stock, only the exhaust is drilled & welded for more sound ...
he wants the same as in my signature all the power upgrades, soo I need your opinions regarding the following to be ordered;
Lloydz Performance Cams 2009 – 2015= USD 520.00
Lloydz Adjustable Timing System = USD 147.00
Cam Cover Gasket LLOYDZ = USD 20.00
PCV Fits 09- Up Vision = USD 379.79
AutoTune (Dual Channel) = USD 396.77
EBC Sintered Front Pads-08-Up Vision = USD 46.39
EBC Sintered Rear Pads Most 08-UP = USD 39.41
NGK Spark Plug 2008- Up = USD 12.48 (2x $ 6.24)
a. Filter Air Vision Performance = USD 139.95
b. Vision Air Filter = USD 94.95
Oil Drain Plug Magnetic = USD 33.95
LLoydz 1/4 turn Throttle Ring = USD 19.95
Lloydz Idle Air Valve = USD 76.99
So anything I forget?
Does he need IAV ?
What Airfilter is the best / nicest for Vision ?
What Cams # HOH-VM1-DR i presume ?
He will need a base MAP with 6400 RPM & Cams & AirFilter srom somebody, hope you guys can help him out ?
His exhaust is only drilled / welded for more sound, what are you guys running for exhaust ?
Thanks guys ....
Cross Country Tour 2014 [B]
BP6666VR is offline
post #2 of 11 (permalink) Old 02-13-2016, 12:31 PM
no need for IAV. How dusty is the country down there. If you have a lot of dust and dirt in the air stock filter would be best. If you do Lloydz top filter clean it once or twice a year.
If you have a good dyno tuner down there ship the auto tune and just have it dynoed.
Write Rylan at the vic shop for map. Tell him about exhaust and cams. Ask about a better exhaust
[email protected]
post #3 of 11 (permalink) Old 02-13-2016, 02:18 PM
Honda East Toledo's Avatar
This gonna be another pallet shipment?
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #4 of 11 (permalink) Old 02-13-2016, 04:23 PM Thread Starter
BP6666VR's Avatar
Thanks VJ ... So my list is pretty complete u think ??
Yes Asia is dusty but I'm running TT and the oil analysis seems ok for dust particles in the oil ..
That Lloyds TOP filter is BLUE so that doesn't seem fair as the K&N oil is RED .... But i like the look of that TOP filter ...
Sadly no DYNO here so only option is to get a GOOD map and buy a autotune with the package....
PAULIE ..... Haaaa hope you can get me some serious discount when the guy wants to do the list above ????
BP6666VR is offline
post #5 of 11 (permalink) Old 02-13-2016, 04:26 PM Thread Starter
BP6666VR's Avatar
O
E
P
S
..... 2014 Vision ... Coz it is WHITE ....
BP6666VR is offline
post #6 of 11 (permalink) Old 02-13-2016, 06:02 PM
not sure your or his exhaust is any good. Stock with holes doesn't produce much.
BP6666VR likes this.
post #7 of 11 (permalink) Old 02-13-2016, 06:16 PM
johneswank's Avatar
Stock exhaust may actually have more power if there isn't enough back pressure. I say that since my bike had cored exhaust done by the dealer and while it sounded great, it actually ran better when I jamed the Thrush mufflers in them. He may be able to find some used stage 1 or Ness big honkers.
Pearl white
Modified Thrush-stuffed exhaust
Victory beacon LED headlight
VicBaggers tips
RF300 amp, Focal IC 165 6.5" speakers
Lloydz timing wheel +4
Lloydz air filter
Victory Hard Lowers
Victory Trunk
Kuryakn Luggage Rack
PC 5
Dyno
O2's unplugged
Chapel Hill, North Carolina
johneswank is offline
post #8 of 11 (permalink) Old 02-14-2016, 05:15 AM Thread Starter
BP6666VR's Avatar
I'm not sure if the exhaust can fit into his budget, the bill will be around 2K including shipping ...
Also not sure if to do a under-drive-pulley for his vision (we still have 1 stock here for narrow tire bikes, never used) .... Last time the pulley tooth bent on another vision, and to fit the reversed gear need to do plenty job tooooo
What are Trush mufflers ? Do they fit inside the original exhaust ??
BP6666VR is offline
post #9 of 11 (permalink) Old 02-21-2016, 02:39 AM Thread Starter
BP6666VR's Avatar
https://youtu.be/fAGQaGYkSyA
Found this video regarding "Thrush" mufflers .... That's a lot of work guys .... Ps how much is the price and are there different models ???
And on the YouTube video was this link ....
https://www.victoryforums.com/showthr...&postid=106188
BP6666VR is offline
post #10 of 11 (permalink) Old 02-21-2016, 02:20 PM
His video isn't that bad and maybe he made it a bigger job than what it is. Keep in mind someone had already been in them mufflers.
Rylan at the vic shop say S1's are not that good.
With a chop saw and a good welder I'm thinking you could do both mufflers in a day and a few beers. That DMILLER had good dyno numbers with his thrush mufflers. You might be able to find some used thrush mufflers if you have craigslist over there
