Grinding Noise - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-23-2016, 08:59 AM Thread Starter
epson390's Avatar
Default Grinding Noise
Hi All -
My buddy is getting a grinding noise when coming to a stop on his 2011 Vision 8 Ball. Its only when your off the throttle and it doesn't stop when the brakes are applied or even when your just coasting. Any ideas?
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #2 of 6 (permalink) Old 06-23-2016, 09:04 AM
Travis P's Avatar
Wheel bearings?
Travis P is offline
post #3 of 6 (permalink) Old 06-23-2016, 09:10 AM
LILMAGS500's Avatar
Belt tension too tight when hot ?
LILMAGS500 is offline
post #4 of 6 (permalink) Old 06-23-2016, 09:35 AM Thread Starter
epson390's Avatar
Originally Posted by Travis P View Post
Wheel bearings?
We were thinking that but it only happens on decel
epson390 is offline
post #5 of 6 (permalink) Old 06-23-2016, 12:08 PM
could it be inside the primary.
Write Rylan and he will answer you hes that good.
Contact - The Vic Shop
post #6 of 6 (permalink) Old 06-23-2016, 12:21 PM
LILMAGS500's Avatar
When my belt was too tight it made a horrible grinding , scraping sound , and it was only noticeable when off the throttle slowing down . Very hard to recognize when on the throttle , even minimally .
