Driving lights mounted to the front tie downs? - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 04-25-2017, 09:26 AM Thread Starter
Tony.v's Avatar
Default Driving lights mounted to the front tie downs?
So under the Vision's highway foot pegs there is the bolt holes that had the "I" bolts for shipping installed. Is there something that I can put into that spot that would bring out a bracket to the front so I could mount an LED driving light onto it? Obviously I dont want it sticking out below the footrest or out to the sides as that would severally hamper cornering but thought if I can put a bracket that would come out the front an LED driving light would go nicely there
Thoughts?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 3 (permalink) Old 05-07-2017, 02:01 AM
VicVisionBulldog's Avatar
The JB Hatch highway pegs mount there so I could certainly see that it would be possible to make a mount that held a light instead of a footrest.
The Hatch pegs just have a flat steel arm that uses a regular bolt to screw into the tipover. I'm not sure if you could have it go under and out the front. You may need to follow the path of the Hatch pegs mount. Honestly, it may be possible to use the standard Hatch mount to secure a light to.
If you could make it work you would know it would not interfere with lean clearance or a fall.
The only thing I don't know what to do with would be the wires for power.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #3 of 3 (permalink) Old 05-08-2017, 09:34 AM Thread Starter
Tony.v's Avatar
Thank you, that is what I am leaning towards. I am looking for something that will work as we speak.
Tony.v is offline
