2017 Vision wont turn over? - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 16 (permalink) Old 05-02-2017, 09:07 AM Thread Starter
Tony.v's Avatar
Default 2017 Vision wont turn over?
As you know I just got a 2017 Vision, this morning it would not start. all lights and everything come on, no error code shows up but the starter motor wont engage not even a click.
The kill switch is normal and Im pulling in the clutch handle. The battery indicates a charge of 14v
Thoughts?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 16 (permalink) Old 05-02-2017, 09:19 AM
Does your fuel pump prime?
post #3 of 16 (permalink) Old 05-02-2017, 09:20 AM Thread Starter
Tony.v's Avatar
yes, it does
Tony.v is offline
post #4 of 16 (permalink) Old 05-02-2017, 09:21 AM
Does the Vision have a kickstand sensor? I know my XCT doesn't...
post #5 of 16 (permalink) Old 05-02-2017, 09:23 AM Thread Starter
Tony.v's Avatar
I dont know. Im sure it was in neutral the N was on the display but I will have to confirm that tonight.
Tony.v is offline
post #6 of 16 (permalink) Old 05-02-2017, 01:21 PM
have you checked the fuses up under the V
do the headlights go out when you push button. That would be a sign of bad power.
down behind battery is the 40 amp relay. with key on you should have power to one side. When you push button you should have power to both sides.
post #7 of 16 (permalink) Old 05-02-2017, 01:29 PM Thread Starter
Tony.v's Avatar
There was no sign of the starter even trying, the lights and everything looked normal and strong. no dimming.
It was about 40F this morning but I doubt that would cause issues? The bike is stored in a garage and it started fine two days ago.
Tony.v is offline
post #8 of 16 (permalink) Old 05-02-2017, 01:49 PM
Can't say I've heard of this before, but maybe it's the starter button itself?
Did you do any electrical work where you had to disconnect any wiring connectors?
post #9 of 16 (permalink) Old 05-02-2017, 01:57 PM Thread Starter
Tony.v's Avatar
Ive literally had it out for only one 50mile ride since I got it from the dealership it has less than 100mi on the OD
It was damaged during delivery to me a month ago so I wonder if when they did repairs something got messed with....Im going to try once more this afternoon when I am home from work before I call them and make some noise.
Tony.v is offline
post #10 of 16 (permalink) Old 05-02-2017, 02:05 PM
I remember that. I wonder if the wire(s) are damaged.
