ABS and linked brakes disable - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 07-17-2017, 11:26 PM Thread Starter
Endeavor's Avatar
Default ABS and linked brakes disable
OK before things get out of hand here is the question and please read to the end before forming a conclusion. And this is not intended to be an ad or promotion
I am in the reverse trike conversion business and need to fully understand the workings of the Victory Vision brake system. During my conversions I normally de-link the brake system and set the foot pedal to run the rear and the hand lever to operate the front brakes. On the Honda GL1800 this is a really easy task and it appears this is also easy on the vision. However the abs may be an issue as I am unsure as to the reliability of transforming this operation to 3 wheels vs 2 wheels and may have to opt to disabling this feature in order to do the conversion safely. Does anyone have any information related to doing the abs disable? Again I am willing to investigate the retention of this safety feature if it is plausible however the dynamics between 2 wheels and 3 are quite different so the retention of ABS may actually be a hindrance rather than a benefit. Any meaningful information would be appreciated.
Thank you
Endeavor is offline
post #2 of 2 (permalink) Old 07-17-2017, 11:34 PM
Default Elio
The new American three wheel car might be worth a look at to see how they do it. If you do not know about it they have 3-wheels also with two up front and one out back. I am pretty sure they are running anti-lock...... Personally I think the cost for your conversion is going to be to high. I would just go back to the standard brake system. Then again that is up to you and your customers, how much do they want to pay for that feature? I know lots of of people like it and some don't. Let us know what you do with it.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
