HID bulb LED replacement? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By PaiN
post #1 of 9 (permalink) Old 07-24-2017, 11:53 AM Thread Starter
Tony.v's Avatar
Default HID bulb LED replacement?
So in the manual there is no indication of what bulb type the HID bulb is. Can a person just replace the bulb with an LED or do I need to do more?
Seems the two high low beam are H4 but what is the HID bulb?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 9 (permalink) Old 07-24-2017, 12:14 PM
Direct replacement. Plug the LED in, adjust and go...
post #3 of 9 (permalink) Old 07-24-2017, 12:51 PM Thread Starter
Tony.v's Avatar
But isn't the HID bulb a different bulb?
Tony.v is offline
post #4 of 9 (permalink) Old 07-24-2017, 01:07 PM
Yes a Hid is a special bulb that requires a special ballast to operate
I don't have one in mine so I can only speak to generalities.
HID's came on some Vic's as a low beam only from the factory. This because it could be left on all the time and a Halogen bulb could supplement it for high beam. It takes a moment for a HID to come to full brightness and to get a instant on high beam this was the factory solution.
They are also sold as a after market kit where you add two ballasts and two after market HID bulbs.
There is a member here who markets them.
Hope this helps some.
Edit: I think the HID low beam was a factory option that could be added to later Cross bikes.
Don't know about visions for certain but they probably were an option available for them also???
If you have two H4 bulbs in your headlight one above the other you don't have that option.
It would be a different sort of bulb coming off a ballast module mounted in the low beam position.
Something like that. Sorry I can't be more helpful.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #5 of 9 (permalink) Old 07-24-2017, 01:12 PM Thread Starter
Tony.v's Avatar
Ok thanks guys for the input, so the Vision's HID bulb uses a standard H4 socket but only uses the low beam setting?
Tony.v is offline
post #6 of 9 (permalink) Old 07-24-2017, 01:21 PM
You'd be far better off waiting for someone who has one to chime in.
I'm just likely to get you going sideways. I don't have my manual or bike where I am right now and I don't have a vision.
As I remember. The HID for a cross bike uses the standard H4 on high beam. The low beam is a special bulb which I remember being quite different and expensive. It had a separate ballast that made it function that was mounted in the fairing.
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 9 (permalink) Old 07-24-2017, 01:26 PM Thread Starter
Tony.v's Avatar
Ok, understood, I will wait on more advice
Thanks
Tony.v is offline
post #8 of 9 (permalink) Old 07-24-2017, 01:30 PM
Crap!... @Tony.v better follow Joe's advice, I was going quick and didn't realize I was in the Vision forum, things might be different in that bike.
SkInM4N likes this.
post #9 of 9 (permalink) Old 07-24-2017, 01:35 PM Thread Starter
Tony.v's Avatar
No problem
Tony.v is offline
