Will these H4 LED bulbs work? - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 13 (permalink) Old 08-31-2017, 08:40 AM Thread Starter
Tony.v's Avatar
Default Will these H4 LED bulbs work?
Hi everyone, I want to replace my main H4 bulbs in the headlight with LED. Will these ones work?
https://www.superbrightleds.com/more...ink/3929/8565/
My concern is the heatsink, will it get in the way
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 13 (permalink) Old 08-31-2017, 11:05 AM
vindex1963's Avatar
I have ones kind of like that in the high beam and I had to reverse the heat sink to make it fit. These don't look like they have a
screw on heat sink unless I missed it.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 13 (permalink) Old 08-31-2017, 11:07 AM
vindex1963's Avatar
What I read about the low beam is you have to move the wiring harness behind the headlight for the LED's to fit.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #4 of 13 (permalink) Old 08-31-2017, 12:52 PM
Keep doing some research. Not sure they wrong but you have to add a load resistors for each bulb. I'm sure there is something out there.
I just changed my H-4's cause one burned out and I would of done LED's but wasn't for sure witch ones to do.
Write this guy he used to have ones for vision and maybe he can give you a answer
Zen Cart!, The Art of E-commerce
post #5 of 13 (permalink) Old 08-31-2017, 12:57 PM
vindex1963's Avatar
Load resistors are for turn signals not headlights.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #6 of 13 (permalink) Old 08-31-2017, 07:29 PM Thread Starter
Tony.v's Avatar
These bulbs are lo-hi beam, Two settings. I'm going to write them and see if the heat sync unscrews.
Tony.v is offline
post #7 of 13 (permalink) Old 09-01-2017, 05:51 AM
vindex1963's Avatar
You should be using H11 our bikes aren't set up to have hi/low in one bulb.
https://www.amazon.com/BPS-Lighting-...illips+H11+LED
Kurbs likes this.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #8 of 13 (permalink) Old 09-01-2017, 01:03 PM
sjaskow's Avatar
That's not correct, Cross Country bulbs are H11s.
My Vision's owner's manual (both electronic and dead tree) says:
Lights
Headlamp (High / Low) H4 55/60W
2006 Boulevard S40 - Traded
2012 Victory Vision - Mechanically stock
sjaskow is offline
post #9 of 13 (permalink) Old 09-01-2017, 01:15 PM
vindex1963's Avatar
I stand corrected his vision does take those bulbs. To be honest I didn't even notice he had a vision.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #10 of 13 (permalink) Old 09-01-2017, 01:50 PM
I think price is outrageous but maybe you can get some information
Headlight Bulb Cree H4 LED in Headlights & Accsy's - Victory Motorcycle Lighting & Electrical - Victory Vision - Shop Parts and Accessories - Your #1 Source for US Made, Custom Victory & Indian Motorcycle Parts
