30 Pin Audio Cable - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 20 (permalink) Old 06-07-2013, 07:26 AM Thread Starter
fivepoints's Avatar
Default 30 Pin Audio Cable
We just took delivery of 2013 VV in the gold mist n bronze metallic
yesterday. I am liking this bike, really a pleasure to ride.
I had the dealer replace the standard aux cable with the 30 pin ipod cable. My understanding was that cable will also charge my iphone.
Plays tunes as expected but does not seem to be charging the iphone.
Not sure if the version matters, its a 3G iphone.
Is anyone using that cable to charge their phone or other 30 pin devices?
Peter Z/
16 Victory Magnum Metallic Black over Steel Gray
MA facing NH
Set up to Tour. Garmin Zumo 660, Show Chrome LED Running Lights, Ultimate Seat, Driver, Passenger Backrest and Luggage Rack
Highway Bars with Closeouts, Lower Air Deflectors, Lloydz Top Filter, Avon Cobra Tires.
Only a biker knows why a dog sticks his head out of a car window.
fivepoints is offline
post #2 of 20 (permalink) Old 06-07-2013, 08:25 AM
Yes I also took delivery of a 2013 vv gold mist I had to get the 30 pin cable as well it does charge my 3G iphone only when the key is in the on or acc position .hope this helps
rlongo69 is offline
post #3 of 20 (permalink) Old 06-07-2013, 08:35 AM Thread Starter
fivepoints's Avatar
Thanks much. I will check the charge icon again to make sure its working properly. See you on the byways of NH. Give a wave!
Peter Z/
MA facing NH
post #4 of 20 (permalink) Old 06-07-2013, 12:49 PM
Tims_04V92TC's Avatar
Have not had any issues, leave an Ipod plugged in and when I was using a 4S charged it as well. Been aiming to get one of the USB/Lighter plug adapters for the trunk to just plug any USB in with. The 30pin cable plugs into 2 differnt cables which you should be able to see to the left of your console. Make sure they are both connected well. One thing I have learned owning a Vision is every time I take a connector apart I lube it up with Dielectric grease. Has reduced my heavy rain annomolies to almost none.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #5 of 20 (permalink) Old 06-07-2013, 02:23 PM Thread Starter
fivepoints's Avatar
Thanks Tims, I will check to see if both connectors are secure. Otherwise the dealer will handle it on the first service check.
Peter Z/
MA facing NH
post #6 of 20 (permalink) Old 06-26-2013, 12:51 PM Thread Starter
fivepoints's Avatar
Just wanted to confirm the dealer did find that one of the plugs not inserted when I brought it in for the first service.
Works like a charm when everything is connected!
They also installed the GPS mount and audio integration installed for my Zumo 660. All works well now.
Peter Z/
MA facing NH
post #7 of 20 (permalink) Old 06-26-2013, 01:54 PM
Good to hear Pete. Was hoping that was all it was.. You figure out how to set up your playlists so you can use your console to speed select? Playlist name= 02 Easy Riding syncs with button two on console and 03, etc... Just checking, took me a while to figure that one out but sure like it going down the road.
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #8 of 20 (permalink) Old 06-28-2013, 09:32 AM Thread Starter
fivepoints's Avatar
Thanks for the tips on the playlist selector. I just reloaded a couple and will have to try.
Also tried streaming Pandora music app and with good cellular it's very good.
Peter Z/
MA facing NH
post #9 of 20 (permalink) Old 06-28-2013, 01:20 PM
Hmmmm, I havent thought of trying that for some reason... Next up!
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #10 of 20 (permalink) Old 12-11-2017, 08:07 PM
i pod cable part # anyone? i need to upgrade to this cable
Imdman is offline
