radio - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 07-16-2013, 02:35 PM Thread Starter
Default radio
I purchased a 2008 vision several months ago, love the bike, but I had a little transistor radio 30 years ago that picked up more radio stations. Just mine, or are they all that bad? Can an external antenna be added to help?
oldrocker is offline
post #2 of 2 (permalink) Old 07-16-2013, 03:07 PM
Tims_04V92TC's Avatar
Yes, a new/better antenna will help. Check out Firestick, they are CB antennas but can also be used in a dual mode as CB/Radio or just radio. Have heard a couple 2-3 riders using those as primary radio and they make a splitter for CB/Radio. They are nice looking antennas.
Also, under the front access panel on the wing, if it is the same as the 11's, you should see a 2nd connector the antenna on the back of the wing cover tucked away on riders right side by the turn signal. May have come disconnected. I actually think I ran across a pic of it today cleaning out some images and tossed it in a folder.. Will look later. The other possible loose connection and it really sucks is under the console facing forward on the bike. Will take a little to get in there and reseat that one. Maybe use a little dielectric grease too to keep out moisture.
Good luck and keep us posted.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
