Hi Yall, I am gathering stuff for future upgrades and want to ask what ohm rating are the front and rear speakers on the VV? 2 or 4 ohm? and has anyone mounted a sub woofer on there VV, I see where Kicker makes a small shallow mounted sealed one and a small amp to boost it. I was also wondering if the rear trunk below the storage area is hollow enough to put one in there. To be more clearer I mean the neck part below the trunk. Thanks Craig
From what I've read the speakers are 4 ohms. I see what you're talking about with the trunk space. I suppose you could possibly fab something to work in the space, it is kind of wasted space. You probably would be stuck with having the trunk mounted all the time unless you wired the sub and amp with quick disconnects. That access panel is where the four bolts that hold the trunk in place are located. There is a filler panel that you can purchase for around $100 that fills in the empty space left by removing the trunk.
Related Threads
Victory Motorcycle Forum
497.1K posts
48.6K members
Since 2007
