vision heat issues - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-18-2013, 10:53 AM Thread Starter
New Member
Default vision heat issues
I have a 2010 vision 8 ball. There is alot of heat that comes up from the bottom of the bike. Has anyone come up with anything to get rid of this problem?
pinionshodan is offline
post #2 of 4 (permalink) Old 07-18-2013, 10:56 AM
Azdave's Avatar
Circulator seat pad helps a lot
Blame it on me
2014 HD Street Glide
2013 Vision Sunset Red
2006 Jackpot sold
2006 Vrod Screaming Eagle (sold)
1972 Kawasaki 1000
Azdave is offline
post #3 of 4 (permalink) Old 07-18-2013, 10:58 AM
CrossRoads's Avatar
Ride faster!
There are a few threads on this subject. Take a look at this one: https://www.victoryforums.com/showthread.php?t=9262 to get started.
CrossRoads is offline
post #4 of 4 (permalink) Old 07-18-2013, 02:18 PM
Tims_04V92TC's Avatar
Heat during low speed/traffic or highway?
Unhook your O2 sensors, install a VFCIII reducing lean engine operation since it will run hotter UNLESS the CA emmisions is going to get you. If it is heat around the thighs at lower speeds, I seen a Vision with heat gaurds that didnt look too bad. For the life of me I cant remember who on here makes the ones for the XCT's but unsure if he did Vision's too.
If highway,
Mixed thoughts on the lowers from differnt riders. I have them and I like them but I don't have an 8ball either so may take away from your look/lines. I keep mine turned in almost all the way a nice flow of air, keeps everything pretty decent up to around 100 so far. I got 10K on the clear plastic lowers, no cracking, adjustment issues or any other problems.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
