Rattling engine - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 08-28-2013, 07:01 AM Thread Starter
Default Rattling engine
I have owned my bike for 4 days and have put 700 miles now. Never road a Vic before I purchased mine. Do all the Victory motors clatter ? Mine is really loud. Maybe its normal for the Victory motor. Thank for the info.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #2 of 19 (permalink) Old 08-28-2013, 07:10 AM
wrightek's Avatar
Victory's are known for their noisy valve trains, it's probably normal but without hearing it I'm just guessing. Mine was really noticeable for the first 2000 miles, either it quieted down or I got used to it.
2012 Kingpin
Thor Exhaust, PC-V + AT, K&N, HID Headlight, Viking Saddle Bags, Grasshopper Sissy Bar
wrightek is offline
post #3 of 19 (permalink) Old 08-28-2013, 08:04 AM
half_crazy's Avatar
Call it "character".....
2006 Victory Kingpin
half_crazy is offline
post #4 of 19 (permalink) Old 08-28-2013, 08:11 AM
MTVic's Avatar
I Call it "Chatter"
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #5 of 19 (permalink) Old 08-28-2013, 10:02 AM
SilvrT's Avatar
If it is new (only 700 miles), it will sound like that. It will quiet down eventually as you get more miles on it. 3-5000 miles is around when they seem to be "broken in". The engine will be quieter and smoother and the tranny will shift smoother. At least this is how it's been with my XCT.
There are a couple or three other things that will have an immediate effect on engine "clatter" ...
1. The type and viscosity of the oil you use (oh no, not another oil discussion!)
2. Removal of the Catalytic convertors.
3. Lloydz timing wheel.
Regardless; however, these motors are solid mounted and are actually part of the frame. All engine sounds will reverberate through the bike thus it will always have a certain amount of "engine clatter" sound.
What you are now hearing is most likely normal .... it will probably be annoying for a while and will be most noticeable under acceleration and at certain rpms. Forget about it .... ride it ... and before long you will not hear those sounds anymore and in fact, many of them will go away.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #6 of 19 (permalink) Old 08-28-2013, 10:07 AM
Luciferiad's Avatar
lol this is New_Kawi_Rider from Vulcanforums who just traded in his Voyager, ain't it?
Welcome to the club, man.
Yeah, Vics are a bit noisy, but not too bad. I image you can hear quite a lot on a vision with that nice air pocket the fairing creates, tho.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #7 of 19 (permalink) Old 08-28-2013, 10:49 AM
what gear are you in when you hear this and what rpm
post #8 of 19 (permalink) Old 08-28-2013, 03:58 PM Thread Starter
Are you stocking me lol ? Yes I am glad to be rid of that thing. 16 months 24000 miles of misery !
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #9 of 19 (permalink) Old 08-28-2013, 04:00 PM Thread Starter
I here it at idle and sitting still when I bring the rpms up. I am sure its normal just never have road or been around Victory motorcycles.
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #10 of 19 (permalink) Old 08-28-2013, 04:08 PM
SilvrT's Avatar
It's hard for us here to diagnose what we can't hear. I'd suggest you take it to the dealer and have them check it out.
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
