Vision Dark Side Tire in Action - Victory Forums - Victory Motorcycle Forum
post #1 of 53 (permalink) Old 02-21-2014, 12:34 PM Thread Starter
TheMike's Avatar
Default Vision Dark Side Tire in Action
You get to see it here. I just got the tire mounted last night. I put about 10 miles on it then decided I need to video this thing.
GoPro Hero3 with the waterproof housing. I stuck a mount to the underside of the rear of the bike and used extensions to get it down to a good position. Ah hell, here's a picture:
The mounts and extensions aren't very rigid hanging there but it got the job done.
The video was taken near my home. I took a round-a-bout twice, got up to 90, made a u-turn in the road, and did S Turns toward the end. The S-Turns were so aggressive you should be able to hear me scrape on both directions.
Hope you enjoy.
Oh, I pretty much ruined the case and lens cover. The rocks that tire threw up at it did it's worse. Oh well. Anything for you guys.
The HD Version
2012 #20 NESS Vision DARKSIDE BABY!
Stage 1 w/D&D pipes + lots of Victory add ons. PC-V w/AT, Lloyd's intake, filter, ATS, & Variable Clutch.
2013 Bushtec Entourage in matching Ness color and graphics - See the PAINTED TO MATCH process
Wife rides a 2016 Gunner
LONGMONT COLORADO
TheMike is offline
post #2 of 53 (permalink) Old 02-21-2014, 12:38 PM
CrossRoads's Avatar
CrossRoads is offline
post #3 of 53 (permalink) Old 02-21-2014, 05:33 PM
Kewl! Thanks for posting!
don07tncav is offline
post #4 of 53 (permalink) Old 02-21-2014, 06:00 PM
wesdalton's Avatar
And??
2010 X C
wesdalton is offline
post #5 of 53 (permalink) Old 02-21-2014, 09:11 PM
vindex1963's Avatar
What a cool video!! Thanks for posting!!!
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #6 of 53 (permalink) Old 02-21-2014, 10:01 PM
Tims_04V92TC's Avatar
Now I don't have to make a video of mine. Good job mike, thanks for the sacrifice of the case.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #7 of 53 (permalink) Old 02-21-2014, 11:01 PM Thread Starter
TheMike's Avatar
You bet guys. Glad to do it.
LONGMONT COLORADO
TheMike is offline
post #8 of 53 (permalink) Old 02-22-2014, 05:08 AM
half_crazy's Avatar
Some people face the camera backward... avoids damage.
2006 Victory Kingpin
half_crazy is offline
post #9 of 53 (permalink) Old 02-22-2014, 07:40 AM
handyhoward's Avatar
Originally Posted by saddlebag View Post
I've always wondered how those cameras don't get damaged when people do those kinds of videos with pebbles pelting the cameras. Now I know...they do.
The video I'd like to see would be how well a car tire disperses rain when cornering. Probably have to coat the lens in Rain-X or some such thing. Anyway, the groves in a standard MC tire typically run at a near perpendicular angle to the rotation of the tire. Presumably, they are there to channel the water to inside and/or outside of the contact patch. There are very tiny channels on the edge of a car tire, more along the angle of rotation and they certainly weren't designed with the intention of dispersing water while operating at or near the sidewall. Be interesting to see how the two types of tires compare at such a thing.
You are absolutely right... NOT! You are extremely limited in your knowledge of tire design of both motorcycle tires and car tires. I have attached a picture of the Hancook tire that Mike is running and an E3 that is standard on the Vision. As one can see from the picture of the Hancook there are directional treads cut in both the center and the edges for the dispersement of water and added traction (and this tire is actually one of the lesser aggressive tread patterns for "darksiders"... or as I like to refer to them, the tire "enlightened"). The picture of the E3 certainly does not have treads anywhere near perpendicular to the rotation of the tire.
If you don't want to ride "enlightened" that's definitely your choice, but please try not to disseminate inaccurate "data" to justify your stance. There was a day within certainly my lifetime and probably yours that all heavy cruisers had "CT's" on them... because the tire industry hadn't as yet realized the tremendous profits to be had by selling specially designed and built motorcycle tires.
Hey Mike... get show. I went with the 185 size as well and don't pull a trailer... I even went with the lesser aggressive designed Kuhmo Ecsta PA31... much quieter and a little smoother.
File Type: jpg dunlop-elite-3-touring-radial-rear-tire.jpg (31.0 KB, 14 views)
File Type: jpg Ventus V2.jpg (712 Bytes, 233 views)
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
Last edited by handyhoward; 02-22-2014 at 07:50 AM. Reason: Forgot the pics... here they are.
handyhoward is offline
post #10 of 53 (permalink) Old 02-22-2014, 08:13 AM
saddlebag's Avatar
Yeah, I looked at Rollin's tire and did notice the perpendicular grooves, hence I withdrew my comment. I'd still like to see how they compare in the rain.
Thank you.
1. The only stance I have is the Buffalo Stance. Somebody gimme a beat.
2. I didn't disseminate anything. I just couldn't detect the pattern in the spinny tire video.
2011 Cross Roads
saddlebag is offline
