Embarrassing 6 speed transmission shifting mojo - Victory Forums - Victory Motorcycle Forum
post #1 of 33 (permalink) Old 04-01-2014, 02:34 PM Thread Starter
Default Embarrassing 6 speed transmission shifting mojo
I've ridden since I was four, I've owned bikes from hyperbikes to touring bikes since I was 16. I ran an MSF school for a while and I've worn out two Goldwings and a Harley. At 53 I now own a 2014 VV and I really like it, a fantastic choice.
But now- Hmmm...this is embarrassing...I guess I am not holding my lips right, I have several times come from a stop in 2nd. I've blown a shift twice and My shifting *sniffle*...well it is sometimes notchy / sometimes smooth. This is embarrasing. I consider good poise on the bike to be a sign of mastery. I visited my doctor, he says: "Sir, you have ESS; Embarrassing Shifting Syndrome."
What to do? Any insight from the 106 cogniscentii? Perhaps you can shed light on what the machine favors from my behavior. Please help my ESS.
Windsign is offline
post #2 of 33 (permalink) Old 04-01-2014, 02:45 PM
CrossRoads's Avatar
Try preloading the shifter. Once you get used to it, your foot will always be a split of a second quicker than your hand/clutch, and the shifts will be of the smooth type. Also fast and firm shifts are quieter than the slow, unsure ones.
However, when in Neutral, there's no getting away from dropping the hammer in 1st.
CrossRoads is offline
post #3 of 33 (permalink) Old 04-01-2014, 02:48 PM
Judge Redd's Avatar
Y'know- I really don't follow the logic of hiding the gear indicator when the clutch is pulled in.. I'm not having these issues- I was going to guess that you were accustomed to 5 speeds? Even my dirtbikes were 6 speeds- so that 's just kind of what I expect.
I know I've damn near bruised my toe trying to shift past 5th on my Dad's FJR.. Fast-but very much needing another set of teeth. Takes me a while to get used to riding that when he's around.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #4 of 33 (permalink) Old 04-01-2014, 03:53 PM
+1 on preloading the shifter for smoother, quieter and more positive shifts. You find that it will slip into gear as soon as the clutch lever enters the friction zone. No need to pull the lever all the way to the grip.
post #5 of 33 (permalink) Old 04-01-2014, 04:06 PM Thread Starter
Sounds like a plan, I'll try it riding home this afternoon.
Windsign is offline
post #6 of 33 (permalink) Old 04-01-2014, 05:22 PM
Lostintexas's Avatar
Spend some more time with it, you'll figure it out. These are a new critter to me as well. However, it is easy to find a lot of folks that whine about Goldwing and Venture shifting.
Make sure the shifter isn't too high also. Easy to adjust and helped me a lot.
Congrats and .
I ride with the Force.
Lostintexas is offline
post #7 of 33 (permalink) Old 04-01-2014, 05:31 PM
half_crazy's Avatar
Shifting insecurity? That usually means your pecker is still growing. Be sure to water it often and once it's done growing your shifting prowess will improve... That, or you could practice shifting...
One other suggestion, make sure the shifter is adjusted right for your foot. You want it just high enough that you can comfortably get your toe under it, that way you will have maximum upward range of motion to pull up on it... and you will have an easier reach to get your foot on top of it when shifting down.
Maybe some ankle strength exercises?
2006 Victory Kingpin
half_crazy is offline
post #8 of 33 (permalink) Old 04-01-2014, 06:07 PM
Give the bike time to break in. Be more postive when shifting. Sounds like your lazy shifting.
post #9 of 33 (permalink) Old 04-01-2014, 07:35 PM
Motorbikerx's Avatar
A lazy upshift into second or third on my 010 Vegas 100/6 will see it dropping back out and at times in third hitting the rev limitet at the same time...very embarrasing!
Blipping to get back into first is a nono too that has had the engine stall on me so I only match revs downchanging in the upper gears, but wonder why it doesnt stall then too?
Yeah on advice from here I tend to preload as well tho the mechanic at Vic in Brissy was horrified when I told him that I preload.
It does get easier with practice tho, and yeah I've now adjusted my shifter closer to my boot.
Even revised my cornering style,
All proof that you can teach an old dawg new tricks!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 33 (permalink) Old 04-01-2014, 07:51 PM
jokerman's Avatar
Arrow
Get the heel shifter peg to help with upshifting. I normally always find nuetral (easy to do on Vic's) when stopped for a light. Adjust the shifter angle & also the floorboard to fit you. There are 3 presets to move the floorboard position (see your manual).
The tranny is the one downside of a Vic. I am on my second Victory & both got what I call "crunchy" after about 10,000 miles. Just something you have to adapt to get used to preloading the shifter.
JOKERMAN
"THERE IS NO SUBSTITUTE FOR VICTORY" General Douglas MacArthur
jokerman is offline
