Vision issues - Victory Forums - Victory Motorcycle Forum
View Poll Results: Which issues have you had?
Wobble/instability 1 3.23%
Cracked headlight 1 3.23%
Radio/Stereo problems 6 19.35%
Oil sending unit failure 0 0%
Belt noise 5 16.13%
Cruise control module failure 2 6.45%
None of the above 21 67.74%
Multiple Choice Poll. Voters: 31. You may not vote on this poll
post #1 of 12 (permalink) Old 10-13-2011, 08:15 AM Thread Starter
half_crazy's Avatar
Default Vision issues
Have you had any of the following issue with your Victory Vision? You may make multiple selections.
2006 Victory Kingpin
half_crazy is online now
post #2 of 12 (permalink) Old 10-13-2011, 08:21 AM
Knocking on some wood before I submit my answer..."None of the above"
2009 Victory Midnight Cherry Vision
108.7 HP and 112.9 ft/lbs Torque
Member of the "Year Round Riding Club"
Proud owner of a Cadillac Crotch Rocket
Joe Schmoe is offline
post #3 of 12 (permalink) Old 10-13-2011, 08:30 AM
While I submitted my response as "none of the above", I will say that the Vision get's pushed around by cross winds and "wash" coming off of vehicles on the highway (traveling in the same direction) much more than any other bike I've had. I attribute it to all the body work, nothing more.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #4 of 12 (permalink) Old 10-13-2011, 10:15 AM Thread Starter
half_crazy's Avatar
For those with wobble/instability issues, did you ever figure out the cause?
post #5 of 12 (permalink) Old 10-13-2011, 12:42 PM
Wobble can be attributed to several factors. tire balance is one and another common culprit is front tire cupping. the latter is common for a dunlop E3 with more than 5000 on it.
bcdad is offline
post #6 of 12 (permalink) Old 10-13-2011, 05:09 PM
I only got to choose 2 issues, there was no voting choice for electrical system failure, rear brakes failure or charging system failure. I guess its too late to knock on wood? LOL
Even still.... 72k+ miles on her and still happy.
Hound is offline
post #7 of 12 (permalink) Old 10-13-2011, 09:50 PM
SkooterRob's Avatar
I had some wobble with cross winds then I took the trunk off and have had no more problem.
2011 Vision Tour Pear White
1999 Kawi 800 Vulcan classic My first bike
SkooterRob is offline
post #8 of 12 (permalink) Old 10-14-2011, 01:19 AM
New Member
I voted none on the poll because rear brake fade/failure was not listed. Still love my bike though!
Guardian is offline
post #9 of 12 (permalink) Old 10-14-2011, 10:55 AM Thread Starter
half_crazy's Avatar
Tell me about the brake thing and the fix, please.
post #10 of 12 (permalink) Old 10-14-2011, 02:29 PM
My rear brakes just went out, 1 minute they were good, next minute, completely gone.
Kevinx bled them, got em back up, worked for a few miles, out again, after a number of attempts of that, replaced the master cyilinder, same thing, replacing the entire line is the only fix.
Hound is offline
