Ipod freezing help - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-07-2014, 01:59 PM Thread Starter
roscoerf's Avatar
Default Ipod freezing help
2013 Vision Ipod classic freezing it is hooked up by way of the ipod adapter . When it freezez I unplug the ipod and re connect it and it works again for a while . How can I correct this
2013 VISION WITCH DOCTORS un baffled muscle mufflers stage 1 tune polk audio 525DXI speakers
3 Other bikes
Michigan.
roscoerf is offline
post #2 of 4 (permalink) Old 05-07-2014, 02:36 PM
gamewarden's Avatar
Is this Ipod classic still a hard drive???? These won't take the bikes vibration.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #3 of 4 (permalink) Old 05-07-2014, 02:47 PM Thread Starter
roscoerf's Avatar
I just found out its not the vibreation but the ignition interferance that causes the issue. Any ipod iphone works EXCEPT THE CLASSIC
3 Other bikes
Michigan.
roscoerf is offline
post #4 of 4 (permalink) Old 05-07-2014, 05:27 PM
Krisd's Avatar
Hey Roscoe- may not be related, but FYI anyway- the classics have a solid hard drive, which is why they are the largest at 160GBs (as opposed to essentially a flash drive for all other ipods and iPhones). And with solid hard drives they mechanically wear after being carried, bumped etc......so could just be your harddrive is on the way out. Mine will stop middway in a song sometimes now so its due to be replaced. Had it for about 5 years.
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
