Power commander install - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 05-23-2014, 10:45 AM Thread Starter
Default Power commander install
Those injector plugs suck ! Any thoughts.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #2 of 2 (permalink) Old 05-23-2014, 10:51 AM
LILMAGS500's Avatar
I used some super long nose pliers or a set of hemostats will work too . After you release the locking clip , you still need to "pinch" the clip to remove it . If you don't do this the plugs will not come off . I wish I knew this at the time . It is a bear to do these ,I don't think anyone will tell you otherwise , good luck .
LILMAGS500 is offline
