CB Radio - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-06-2014, 03:55 PM Thread Starter
Default CB Radio
Good Afternoon All,
Can anyone tell me if the CB Radio can be heard thru the external speakers as well as through the headset? Was wondering if you could listen to it on the "Mix" mode for headsets like the radio.
Thanks!!
2012 Ness Vision - Nuclear Sunset with Ness graphics
rseven923 is offline
post #2 of 6 (permalink) Old 06-07-2014, 12:20 PM
Originally Posted by rseven923 View Post
Good Afternoon All,
Thanks!!
I listen to mine that way, I honestly don't know if they are heard through the external speakers or not, because my helmet speakers are louder than the others.
1967 honda 305 scrambler, 1968 met pickup, pickup won
1969 honda 350 scrambler, sold 1972
1973 yamaha 750, sold 1980
1980 yamaha 1100 special, sold 1992
1986 yamaha venture royale, bought 1991
2002 royal star venture, bought 2005
2011 victory vision, bought used Aug. 2012
Northwest Ga
retired construction worker
jack30755 is offline
post #3 of 6 (permalink) Old 06-07-2014, 12:27 PM
Default cb radio
While on A trip up the BRP last week all of A sudden my riding pals could not here me, I could here them, A couple days latter all of A sudden it started working again. Just wondering if anyone else has had this problem. I had something similar happen on my Star venture last year, except everything on it quit, checked out all the cords, checked the radio and cb, my untrained self could find nothing wrong, Put it back together and it worked.
Northwest Ga
post #4 of 6 (permalink) Old 11-03-2014, 09:11 PM
I had a Victory CB on my XCT with the Victory headset. It was always dropping one of the helmet speakers and one time it dropped the mic. I found that the mic mount was loose when the lower half with mic fell off. When I snipped it back on everything worked. So after that every time one of the helmet speakers quit I'd push it back together. The mount is two piece and the lower part with the mic just snaps on and will came loose or fall off. When it's loose you start to loose things in the helmet, speakers or Mic. The J&M headsets with the round plug on the side of the helmet will do this also. But when it falls off all that falls down is the cable. J&M tried to fix this with a strap that holds the cable on but all this does it keep it from falling off. It still comes loose and drops speakers and the mic. I'm always having to reach up and push the plug back in, to get the speaker or the mic to work. I wish someone would make better headsets for the helmets. I've had CB's on both of my Goldwings and my XCT. I plan to put one on my Vision because must of the riders I ride with have them. I don't know how many J&M headsets I have had quit working on me over the years. Finally started buying the cheapest ones I could find as the expensive ones didn't last any longer. I have a large pile of adapter cords that don't work or only work once and a while if you move them around.
2014 XCT15 th Anniversary Limited #077 D&D's
Midnight Cherry 2009 Vision Victory Stage 1 mufflers traded off
(XCT totoled on dragon tail 8-10-14)
Black 2012 Cross Country Tour that now has 14000 miles. 195/55-R16 Rear, Stone 709 on front.
PCV, Autotune, D&D's /Lloydz's air filter.
strip removed. Added CB 7/27/14 it works! LOL
2005 Yellow Goldwing Motor Trike Sold.
93 GL1500 red
Moto Guzzi's for years 71 750 Ambassador fairing and bags. 79 1000 G5 with fairing, saddle bags and trunk.
GrogAV is offline
post #5 of 6 (permalink) Old 11-04-2014, 10:39 AM
Oldman47's Avatar
There are much better headsets. The SENA SMH-10 is the one that I have but there are other well known brands out there too. MY SENA has been installed in my helmet for over 2 years now with no issues. It runs off of a bluetooth connection so there is no cable or cord to fall out like I experienced using the stock HD headset in my helmet. Batteries last for an all day ride with my wife and I using the headsets for an intercom, having them continuously on, not just using the VOX feature. Since you never experience any jerk on the connectors you also do not damage all the wiring to the earphones or microphone from the main unit.
Oldman47 is offline
post #6 of 6 (permalink) Old 11-04-2014, 07:38 PM
Tims_04V92TC's Avatar
Had the VIC CB and JM headsets for 28k now and no issues. Vic CB headset flat junk. Only issue I have is those ear piece connectors get loose but dialectic grease helped. No mic issues on JM but the VIC one was worthless.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
