brake lever to long - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-05-2014, 02:27 PM Thread Starter
roscoerf's Avatar
Default brake lever to long
Has anyone considered a shorter brake lever?
I am looking for someone who sells them.
2013 VISION WITCH DOCTORS un baffled muscle mufflers stage 1 tune polk audio 525DXI speakers
3 Other bikes
Michigan.
roscoerf is offline
post #2 of 7 (permalink) Old 07-05-2014, 03:35 PM
Lostintexas's Avatar
What makes you think it is too long? Can't reach it?
I would think the Vision controls would adjust much like the XBikes. Could be wrong on that though. Doesn't seem to be all that difficult a system, but handy and can't believe more don't take advantage of a similar set up.
A certain amount of mechanical advantage is needed to make the thing effective. Most probably don't even use the rear pedal on a Vision since the brakes are linked. Of course some have said it will dive a bit at slow speeds. Haven't spent enough time on one to learn the particulars, so hopefully the pilots will get home from their ride and post, but this should give you something to check on until then. LOL
Cheers.
I ride with the Force.
Lostintexas is offline
post #3 of 7 (permalink) Old 07-05-2014, 05:29 PM
A short lever will take twice the effort to pull.
Pulling the lever at the end take a hole lot less effort.
There is no way to adjust the clutch to make it easer with a hydraulic clutch
post #4 of 7 (permalink) Old 07-05-2014, 05:51 PM
Weeds's Avatar
If im not being to forward here, pull the lever from where you think a shorter lever would be and see what you think, as VJ said, shorter would take more effort....
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 7 (permalink) Old 07-05-2014, 08:43 PM
Oldman47's Avatar
Welcome roscoe. Have you tried just adjusting the brake to suit you? I have my brake set for minimum lever movement using the OEM adjustment. I find that makes it feel perfect for me.
Oldman47 is offline
post #6 of 7 (permalink) Old 07-07-2014, 11:50 AM Thread Starter
roscoerf's Avatar
lol yes I can reach it I guess I'm looking at the feel as well how the controls set I'm grabbing the brake lever in the curve not on the end if it was a different shape like on my track bike I would have actually more mechanical advantage than where I am now . I do see that I cannot adjust the controls inward. It's a feel thing again. Maybe "Shorter" was an incorrect description.
3 Other bikes
Michigan.
roscoerf is offline
post #7 of 7 (permalink) Old 07-07-2014, 09:03 PM
cut it off. If you want a stock one backe there only a $125
