step 1 to rear tire replacement vision - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 07-17-2014, 05:12 PM Thread Starter
Default step 1 to rear tire replacement vision
1.http://youtu.be/ZmDEhUIVrYw removal of any extra rubber!
2. put bike on a good lift
3. jack up rear of motorcycle
4. remove suspension linkage bolts
5. remove rear axle
6. slide belt and brake out of the way to remove wheel
Imdman is offline
post #2 of 2 (permalink) Old 07-21-2014, 03:47 PM
Tims_04V92TC's Avatar
Careful of that speed sensor cable for the abs when dropping the swing arm.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
