Rear Brake Big Bucks - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 08-05-2014, 07:40 PM Thread Starter
Default Rear Brake Big Bucks
So am I to understand, after talking with my local Victory service manager, that the rear brake master cylinder has NO rebuild kit but Victory had quite a bit of trouble with them?
He told me it normally ran $650/700 to replace it. Maybe I'm just cheap but that seems just a bit steep to me. I had to rebuild the rear master cylinder on my Concours and even though I'm no mechanic, it wasn't a hard job. Even considering my Vision has ABS (which does cause me some pause) I'm having trouble believing the master can't be rebuilt.
2010 Blue/Sandstone Victory Vision
One well-traveled Windward pop-up camper
Mid-Michigan
FarRyder is offline
post #2 of 4 (permalink) Old 08-05-2014, 10:49 PM
why are you rebuilding it?
If you lost your rear break pump pedal hold down and open right hand front caliper CENTER bleeder. You might have to do it a couple times to get the air out. No need to bleed the rear caliper.
On the rear break line where the metal meats the line there is a bad crimp.
I have lost rear break once about two years ago. haven't had a problem since and the bike sits for five months over the winter.
post #3 of 4 (permalink) Old 08-06-2014, 05:16 PM Thread Starter
I'll certainly give that a shot and hopefully that's all it needs because that price he quoted me was WAY ridiculous as far as I'm concerned.
Mid-Michigan
FarRyder is offline
post #4 of 4 (permalink) Old 08-06-2014, 07:02 PM
Tims_04V92TC's Avatar
Just throwing it out there about changing out the fluid if your going to bleed. I for one never changed my brake fluid. Ever! UNTIL I had issues on my truck and the crap that came out out was unbelievable and my sticking caliper went away. Just a thought.
On the flip side, I had to bleed mine one time due to a annoyance with my rear brake about 6k ago no more issues. Good luck.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
