Fuel pump a little on the loud side - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 09-26-2014, 09:13 PM Thread Starter
Default Fuel pump a little on the loud side
I have about 600 miles on my Gunner. Since the first day I rode it, I noticed somewhat of a constant "ringing" noise coming from the tank. It has gotten a bit louder since then. The dealer confirmed it was the fuel pump and that it was "normal". It doesn't bother me much, although I'd rather not hear it. Can anyone relate? Thanks.
Jéan Saysee is offline
post #2 of 8 (permalink) Old 09-26-2014, 09:30 PM
fordwrench's Avatar
I can only hear mine when I turn on the ignition and the pump charges. Don't let the dealer BS you and have the pump fail after the warranty is up make them change it now.
15 Gunner
83 CB1100f
09 KLX250S
76 CB750K6
73 Kawasaki H1 Triple
78 KX250A94 KX250
fordwrench is offline
post #3 of 8 (permalink) Old 09-26-2014, 10:37 PM
Travis P's Avatar
Both my Vic's I can only hear the pump when key is on position and pump is priming.
Travis P is offline
post #4 of 8 (permalink) Old 09-27-2014, 06:40 PM
rhino 2's Avatar
Same here [at idle after priming] with my Gunner I have a little over 7 hundred miles on it.
I'm thinking because the seat is so low you're real close to the pump?
Or the engine is so quite you hear it.. Any way when I get a chance i'll let my dealer take a listen, And more than likely he'll tell me...
1] They all do that....
2] That's normal....
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #5 of 8 (permalink) Old 09-28-2014, 12:00 PM
Think of it your fuel pump is submerged in gas there is no way you should hear it. Yes dealer might be BSing you. Have them do a fuel pressure test it should be 50 psi
post #6 of 8 (permalink) Old 03-31-2015, 08:05 PM
I hear it too and have 3k miles.
clemvm is offline
post #7 of 8 (permalink) Old 04-13-2015, 09:04 PM
rhino 2's Avatar
I'm a little late on this, But a while ago I went to my dealer and started a Gunner that he had on the showroom floor, Sounds the same as mine.. So I'll take it as normal..
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #8 of 8 (permalink) Old 04-14-2015, 08:58 AM
Default My High Ball was loud to begin with
It is much quieter now
I took it in also so that they did at least have it on paper for the future.
18,000 later and all is good.
2013 HIGH BALL
heddonbaits is offline
