oil filter brands - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 10-04-2014, 04:06 PM Thread Starter
eotsis1's Avatar
Default oil filter brands
was wondering about alternate replacements to the Victory (Polaris) brand in my '09 Vision 106/6 motor. I had some left over Hiflo 303 filters from my last bike that will fit but are about 1" shorter. Is there only the issue of capacity? I know there is another Hiflo 198 that is supposed to be the replacement.
Would there be any things like pressure relief , flow capacity, or cooling that would suggest this is not a good idea?
1 Corinthians 15:57 But thanks be to God! He gives us the victory through our Lord Jesus Christ.
2009 Vision... Lloyd cams, pipes, timing wheel +4, power commander V, gps, xm, centramatics, DARKSIDE
eotsis1 is offline
post #2 of 18 (permalink) Old 10-04-2014, 05:46 PM
You should go to Hi Flow web site and read up on that filter.
Not sure why you would ask us when you can get it right from the horses mouth sort of speak.
I use Wix a long with a couple of hundred other Vic owners
post #3 of 18 (permalink) Old 10-05-2014, 10:29 AM
bsbabcock's Avatar
I tell ya, I pulled my K&P filter the other day to remove the stock headers, and that magnet on the filter just plain works. Been pleased with it. I believe the oil is flowing better and the filter is super easy to clean and maintain. It gets my vote.
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #4 of 18 (permalink) Old 10-05-2014, 05:14 PM
XzombieX66's Avatar
i use this and i love it, bought mine off Amazon for 70.00
http://pcracingusa.3dcartstores.com/...PCS2_p_31.html
Big Gonzo Mufflers
Lloydz adjustable timing wheel
Ness RAD III Mirrors, Ness Deep cut grips
Vic Hids, Vic Baggers Tarzanz Bars +1 rise +2 pull
Vic Baggers 6.5 degree triple trees
Gorby's Machine 23 inch wheel- Windmill contrast cut,
23 inch wrap around front fender, Whitewall choppers Radio control Bezel and 1.5in Lowering link...
XzombieX66 is offline
post #5 of 18 (permalink) Old 10-05-2014, 06:09 PM
bsbabcock's Avatar
Nice. The guts look identical to the K&P.
post #6 of 18 (permalink) Old 10-05-2014, 06:37 PM
toejam's Avatar
http://www.discountfleetsupply.com/wix51356.html
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #7 of 18 (permalink) Old 10-05-2014, 07:42 PM
vindex1963's Avatar
We be #5.
Click.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #8 of 18 (permalink) Old 10-05-2014, 08:52 PM
Oldman47's Avatar
I am using a K&P model S-1. It is the listed model for all Victory engines.
Oldman47 is offline
post #9 of 18 (permalink) Old 10-14-2014, 08:02 PM
Default K&P
Anyone else got any thoughts about the K&P ? I like the idea but I think ill start changing my oil every 2500 miles just to get my moneys worth out of it. And those COOL looking dip sticks that witchdoctors sells. IM always going to be buying something I get the feeling.
2014 victory XC, white.
rcmike is offline
post #10 of 18 (permalink) Old 10-14-2014, 08:58 PM Thread Starter
eotsis1's Avatar
I wonder weather there's really a cost savings or a cooler motor with the K&P unit.
Not saying there couldn't be but there's no before /after temperature comparison test to substantiate the claim. It would seem the amount of time the oil spends in the filter is insignificant enough to radiate any heat. However adding mass that is the makeup of the filter should absorb and eliminate some but significantly enough to claim... idk.
How many regular filter vs k/p oil changes would it take to recover initial expense? You're using brake cleaner and occasional replacement O-rings in exchange for a regular filter. Some savings per change but $200? Would take 10 years to see the cost benefit. The performance and/or longevity benefits can't be seen for some time til identically used motors are disassembled and compared using both methods.
Then there's the added time to clean the filter and who's to say it's really clean and you don't put contaminants back into the motor?
Ha, I'll prolly end up getting one anyway someday.
eotsis1 is offline
