Oil reccomendations? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-22-2012, 02:31 AM Thread Starter
New Member
Default Oil reccomendations?
Hey everyone I knows there's an Oil forum on the home page but does anyone have tips on what type to use and what type to stay away from as far as oil for a Vegas 8ball? I have an 07 with just under 3,000 miles on it. I had a cycle shop change the oil for me last month when I bought it and I'm getting a lot of slippage... Not sure what they used but I remember it was a syn blend. This is my first bike and I plan on doing the oil changes myself from now on. Any tips on oil would be appreciated!
Macielusmc is offline
post #2 of 6 (permalink) Old 04-22-2012, 07:00 AM
I think if you used the search function at the top of the page; you will get more info than you could possibly use. There are just about as many opinions on oil as there are members here.
post #3 of 6 (permalink) Old 04-22-2012, 11:37 AM
YES do the search forum
post #4 of 6 (permalink) Old 04-22-2012, 01:39 PM
Default clutch slippage.
A couple of things. Did you or whoever changed the oil the last time overfill the engine with oil? Also do you have any free play in the clutch lever? If the engine is overfull it can cause clutch slippage because more of the clutch disc are covered in oil than recommended. If there is no free play in the clutch lever it is just like you riding around with the clutch lever pulled in partially with your hand,thus causing clutch slippage.
Speedblue is offline
post #5 of 6 (permalink) Old 04-24-2012, 08:23 AM
Roadrocket's Avatar
What Speedblue said. With only 3000 miles on it I'd look for something other than the oil as the cause.
The Truth is Often Painful
2011XC
Roadrocket is offline
post #6 of 6 (permalink) Old 04-24-2012, 03:18 PM Thread Starter
New Member
Thanks for the input, I'm thinking maybe the guy over filled the oil because he told me he was surprised at how much oil the bike took. I think I'll just stick to doing it myself from now on. As far as oil goes, I think I'll try out Amsoil this time.
