What oil do you use - Victory Forums - Victory Motorcycle Forum
post #1 of 47 (permalink) Old 04-25-2012, 10:25 AM Thread Starter
worm5932's Avatar
Default What oil do you use
NO OPINIONS!!!!!!!!!!!
Please state what oil you use and keep the your wrong I'm right to yourself. I spent the last hour reading in this section and I found tons of opinions. However not one case of an oil related failure, or failure at all.
so please only state what oil and filter YOU use.
worm5932 is offline
post #2 of 47 (permalink) Old 04-25-2012, 10:38 AM
ridinman's Avatar
Victory 20/40, stock filter. I don't buy the "kit", just the 5 Qt jug and a filter.
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #3 of 47 (permalink) Old 04-25-2012, 10:56 AM
Don't bring this up again go to search and read your hole summer away.We all have our own idea what to use and its Been disused a million time a long with what oil filter to use.
If you don't find enough reading here go to the net and there will be more for you
post #4 of 47 (permalink) Old 04-25-2012, 11:40 AM Thread Starter
worm5932's Avatar
I'm aware that I can read all summer but you didn't read what I posted. NO OPINIONS!!!!
Ridinman replied correctly. Simply state what you use, nothing else.
worm5932 is offline
post #5 of 47 (permalink) Old 04-25-2012, 04:13 PM
Roadrocket's Avatar
Suzuki 20-50 syn-blend
The Truth is Often Painful
2011XC
Roadrocket is offline
post #6 of 47 (permalink) Old 04-25-2012, 05:13 PM
Victory Kit.
If Rotella had JASMO rating on syn/dino blend in 20/40, then I would use it. Still might go Rotella syn/dino blend in 15/40 one of these days.
Tripntx, Retired US Air Force, 2A390 Aircraft Superintendent
2012 Red Cross Country Tour (on order 30July2011)
Llyodz VM-1 Cams
Settled on D&D exhaust
Victory Performance filter and seal removed
PCV & AT & LCD-200
Passenger hand holds, Passenger arm rests, side bag rails
'06 FJR1300AE
K&N, Full Holeshot exhaust system, PCiii, Dark side with 17" car tire on rear
tripntx is offline
post #7 of 47 (permalink) Old 04-25-2012, 05:21 PM
RedRocker's Avatar
Post
Switched to Amsoil 20W/50W this month w/K&N filter. Not looking back!
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #8 of 47 (permalink) Old 04-26-2012, 03:29 PM
Amsoil 10/40 and Wix filter.
TheBarry is offline
post #9 of 47 (permalink) Old 04-27-2012, 07:00 PM
vindex1963's Avatar
I use oil that I bought at the store.
Talk about a beat to death subject. I posted an oil report so look there.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #10 of 47 (permalink) Old 04-27-2012, 07:40 PM
buddoggin's Avatar
buddoggin is offline
