Rotella T5 - Victory Forums - Victory Motorcycle Forum
 20Likes
post #1 of 229 (permalink) Old 12-09-2014, 05:49 PM Thread Starter
vindex1963's Avatar
Default Rotella T5
Started investigating T5 blend 15w-40 as an alternative to the T and T6 blend I currently use. What what I've read it's JASO MA but they've not had it tested so it's not listed and I believe this considering it's not energy saving or energy conserving and that's the evil additive that messes up the clutch. They had T and T6 tested and didn't want the expense of the testing for T5.
I may try it closer to summer to see how it stands up to the Phoenix 110+ summer heat.
T5 Technical Data sheet
Click
T6 Technical Data Sheet
Click
Triple T Technical Data Sheet
Click
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 229 (permalink) Old 12-09-2014, 06:22 PM
Lostintexas's Avatar
I've never seen the T5 in 15-40 around here, but know we don't see all the blends.
Many of us were using Rotella long before it became JASO certified. It worked fine then too.
Good luck with it.
I ride with the Force.
Lostintexas is offline
post #3 of 229 (permalink) Old 12-09-2014, 07:37 PM Thread Starter
vindex1963's Avatar
Good luck with it.
Good to hear. No doubt it's fine for the reason I stated above not listed as energy saving.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #4 of 229 (permalink) Old 12-09-2014, 07:44 PM
Konga63's Avatar
Please let us know what your end results are. Thanks, Vin.
2007 Ness Jackpot
Konga63 is offline
post #5 of 229 (permalink) Old 12-09-2014, 08:03 PM Thread Starter
vindex1963's Avatar
king4wd likes this.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #6 of 229 (permalink) Old 12-09-2014, 10:24 PM
Rebel Biker's Avatar
I just run pure T5, no blending. I've not had it analyzed yet. I wanted to get the engine broke in then analyze it on winter miles because that's where all my tests have done the worse at. I should be testing in a couple thousand miles.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #7 of 229 (permalink) Old 12-09-2014, 10:29 PM
Konga63's Avatar
Curious to see what your results will be. Thanks.
2007 Ness Jackpot
Konga63 is offline
post #8 of 229 (permalink) Old 12-09-2014, 11:30 PM
I have posted in another thread, the report of the analysis on T6 that went 7,000 miles in my XR. The Lab recommended I go 9,000 mile on it. Good stuff that Rotella.
post #9 of 229 (permalink) Old 12-10-2014, 05:33 AM Thread Starter
vindex1963's Avatar
Look what it's designed to protect our little motorcycle engines aren't anything compared to the big rigs. It's known as the million mile oil for a reason.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #10 of 229 (permalink) Old 12-10-2014, 08:15 AM
saintdruss13's Avatar
When I started using T6 my 1st change I did at 3000 miles and the oil still looked good so I went to 4000 miles then to 5000 miles. I do my oil changes around 5000 miles now but even then the oils not black and I'm having no shifting issues.
I didn't even know T5 was an option so I haven't looked for it, is it less expensive or what's your reason for wanting to try it? My oil changes cost around $50 with T6.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
