rotella t 6 - Victory Forums - Victory Motorcycle Forum
 9Likes
post #1 of 153 (permalink) Old 03-10-2015, 05:46 AM Thread Starter
spanknut24's Avatar
Default rotella t 6
I see a few guys liking this oil but I can only seem to find the t6 diesel .Ive been to a couple different wally worlds. There has to be a difference right?
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #2 of 153 (permalink) Old 03-10-2015, 06:30 AM
vindex1963's Avatar
That's the one and only.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 153 (permalink) Old 03-10-2015, 06:41 AM Thread Starter
spanknut24's Avatar
I would presume safe to use then? That is the brand you use right?
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
06 kp traded in.
post #4 of 153 (permalink) Old 03-10-2015, 06:43 AM
Pauljp's Avatar
The main thing to look for is JASO spec which the T6 has so it is good. I am using it right now in my CCT.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #5 of 153 (permalink) Old 03-10-2015, 06:54 AM
LILMAGS500's Avatar
Spanks , this is what I use also .... Great stuff !
LILMAGS500 is offline
post #6 of 153 (permalink) Old 03-10-2015, 07:26 AM
MonsterMash's Avatar
another T-6 user chiming in. I run it in mine and have absolutely zero issues with it or shifting or anything negative. change mine every 3500 miles...
you got your jesus on the dashboard, the devil's under my hood. you're takin' down to legal, i'm pulling it up to no good.
god is your co-pilot, i let satan ride shotgun, you pay a toll to get to heaven, but on the road to hell there's none..... \m/ \m/
2010 Cross Roads
Navy - Its not just a job, its an adventure :)
MonsterMash is offline
post #7 of 153 (permalink) Old 03-10-2015, 08:17 AM
vindex1963's Avatar
Change mine every 5000 closing in on 45,000 miles.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #8 of 153 (permalink) Old 03-10-2015, 08:17 AM
slickvic's Avatar
Is the T6 a full synthetic? What other blends are ok to use from Rotella?
slickvic is offline
post #9 of 153 (permalink) Old 03-10-2015, 08:28 AM
I use rotella's regular 15w-40 dino oil
vcc14 is offline
post #10 of 153 (permalink) Old 03-10-2015, 09:21 AM
vindex1963's Avatar
Actually I use 4 qts T 15-40 and 2 qts T6. My 04 holds 6 qts.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
