Oil drain Plug - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 10-12-2009, 07:13 PM Thread Starter
Default Oil drain Plug
Is there a special tool to remove the oil drain plug on the 2002 v92?if so what is it called and where can i buy it?
biggunsbbq is offline
post #2 of 5 (permalink) Old 10-13-2009, 12:03 AM
The Diamond
diamondrmp's Avatar
METRIC allen wrench. you can buy it at any tool store
diamondrmp is offline
post #3 of 5 (permalink) Old 10-13-2009, 08:02 PM Thread Starter
Thanks for the reply it was a #10 metric. Sorry to say I didnt own any metric allen wrenchs before. However it wouldnt work for me. Once I got the bike high enough to see under it I could tell the previous owner had stripped it out. That was the main reason I was having an issue. I had to drive a quality craftman 3/8 extenion into the plug to remove and replace it. Was starting to look like it was going to have to be drilled and tapped out.
post #4 of 5 (permalink) Old 10-13-2009, 08:16 PM
The Diamond
diamondrmp's Avatar
Thats good to hear. All's well that ends well!
post #5 of 5 (permalink) Old 10-25-2009, 01:43 PM
New Member
Biggun, I have the same bike, and most every fastner on it is metric. Invest in a good set of metric hex head (I use the allen head sockets the most) and metric wrenches and sockets.
Slice is offline
