Is this a newer oil from Mobil One? 20W-50W - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 26 (permalink) Old 08-29-2012, 10:03 PM Thread Starter
sixshooter_45's Avatar
Question Is this a newer oil from Mobil One? 20W-50W
Mobil 1 V-Twin 20W-50
Mobil 1™ V-Twin 20W-50 synthetic motorcycle oil is formulated to help offer outstanding protection in 4-cycle, V-Twin type engines, particularly those which are air cooled and tend to run hotter than other types of engines.
Mobil 1 V-Twin 20W-50 motorcycle oil will help provide excellent performance in motorcycle engines that are designed with a common engine/transmission lubrication system or where the engine lubrication system is separate from the transmission system. In the case of the latter, follow the manufacturer's recommendation for the type of fluid to be used in the transmission. It is also designed to help provide the proper frictional characteristics necessary for wet-clutch engine/transmission systems.
I ask because I don't remember them having a 20w-50w, isn't this the weight that Victory uses?
Should be good to use: Optimized wet-clutch performance
  • Meets JASO MA.
sixshooter_45 is offline
post #2 of 26 (permalink) Old 08-29-2012, 10:05 PM
No its not new, and no Victory uses 20-40W semi.
Frankyoz is offline
post #3 of 26 (permalink) Old 08-30-2012, 07:55 AM
ammo_umb's Avatar
I'm testing it right now and am happy with it so far. The best part is that it's available at WalMart and is about $6 per quart. I've ran 20W-50 in my bike since the 500 oil change and can't say anything bad about it. I should advise warming your bike up until the engine is warm to the touch in the winter (if you live in an area that freezes). My garage gets down to the low 50's and the bike starts slightly slower than in the summer. When I start the bike at work in the mid 20's to low 40's it starts much slower which is partially because of cold soak on the battery and partially from thickened oil. If the oil is thick enough to slow starting it's too thick to put a load on the engine until the engine is warm to touch.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #4 of 26 (permalink) Old 08-30-2012, 08:46 AM
handyhoward's Avatar
If you live in a colder part of the world and ride in cold weather and are not using a 5wt or at least a 10wt multi-viscosity oil, you may be doing damage to your engine every time you start it. It's not just about letting the engine warm up (which is good) it is also about lubrication when starting the engine when it is very cold. A 5wt-40wt such as T-6 is better fitted for this than a 20wt-50wt, especially in a Victory with it's air/oil cooled engine... a 50wt really isn't needed in a Victory because of the oil flow thru the cooler then thru the cylinders then into the oil pan. 50wt was really develop for Harley's because they operate at higher temperatures due to their lack of oil cooled cylinders. Even here in Florida a 40wt is all that's needed for a Victory... but run a 50wt in a Harley for sure.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #5 of 26 (permalink) Old 08-31-2012, 09:17 AM Thread Starter
Smile
Thanks, you're correct, I'd looked it up earlier but had memory fail, I'll probably go with Mobil 1 Racing 4T 10W-40 or Amsoil.
post #6 of 26 (permalink) Old 08-31-2012, 11:02 AM
Why would you even come here with out going to Mobil first to find out all the facts.
post #7 of 26 (permalink) Old 08-31-2012, 02:37 PM
jsims006's Avatar
I changed the oil at 500 miles with Mobil 1 V-Twin oil. I am almost to 2700 miles right now and I haven't noticed any issues.
The engine seems quieter to me than with the factory oil, probably because semi vs full OR break in oil vs changed oil. Not really sure.
All I know is Advance carries oil change specials on it, and if I can't get a Mobil 1 filter, then I go for a Wix filter available at Napa for $6.
My clutch does not slip, bike does not leak, engine does not overheat, and throttle hand does not let up.
2012 Victory Jackpot 106
Lloydz Torque Tubes
Power Commander V
RPW Thor 2:1
96 HP / 112 Torque
jsims006 is offline
post #8 of 26 (permalink) Old 08-31-2012, 02:48 PM
Although I use Rotella T6 5W-40, in colder climes, I aim an electric heater at the lower part of the engine for about 1/2 hour prior to commencing a ride. That way the oil has gotten a bit warm for a safer start up. Its easier on the battery too. In winter, I keep an automatic charger hooked up to the battery to keep it from going into hibernation.
post #9 of 26 (permalink) Old 08-31-2012, 08:57 PM
Ah, VisionJohnny if only we were all lucky enough to be gifted with your incredible insight and wisdom. What a wonderful world that would be.
2012 XCT White
San Antonio, TX
Honda CB350, Penton 125, Penton 175, Honda MR 175, Honda TL250, Yamaha IT 175, Husky 250CR, Husky 360 Auto, Husky 390WR, BMW R90/6, Honda CX 500, 84 Goldwing, 93 Goldwing, 98 Goldwing, 2012 Victory XCT
thumbgone is offline
post #10 of 26 (permalink) Old 09-08-2012, 09:34 PM
robvision's Avatar
I have been using Rotella 5-40 for years. And just to see how it sounded in my xct I gave it a shot. At the time it was very hot and the bike shifted harshly and the roller rockers were even louder.
So I dumped that and tried 20-50 AMS OIL and I have to say the bike shifts much better and the roller rockers are much quieter.
BUT when the temperature drops I want Rotella T 5-40 or a 10-40 oil in the motor NOT 20-50
Remember 20-40 and 20-50 should be 20w oil at zero
The 50wt just protects better if the motor was to get REAL HOT....
The oil cooler does very little if there is no air flowing through it - like being stuck in traffic.......
Personaly if I am going to pay big bucks for oil it is going to be Full Synth
Rob
Rob
2010 V Star 650 Custom (Wife's)
2013 XCT 2013 Suzuki KQ750 AXI Power Steerring
Victory Sport Touring Flag Ship
Lloydz Idle Air Valve
Lloydz PTW
60,000 km
Rear Rack
Passenger Grab Handles
Modified Heel Shifter
HID Low
Oil Temp Gauge
Ride-On TPS
Modified Stock Pipes by Thrush
K&N air filter
G-man Bully FI Controller
Heat Troller
LED Driving lights
PCV with AutoTune
robvision is offline
