Those using rotella. T6 - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 09-03-2012, 08:39 PM Thread Starter
NJ8BALL's Avatar
Default Those using rotella. T6
Have you folks noticed any odd or new sounds? I used it 1 time in my Royal Star and if I remember correctly it made more noises with it.
Sent from my SPH-L710 using Motorcycle.com Free App
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #2 of 8 (permalink) Old 09-03-2012, 11:18 PM
Been using T6 5W-40 in my 2010 XR for about 7K miles with no complaints.
RICZ is online now
post #3 of 8 (permalink) Old 09-03-2012, 11:19 PM
Marius's Avatar
Are you talking about the 5w40 oil?
Victory calls for 20w40, so I would imagine that until the oil heats up you're going to hear some excess valve train noise, because 5 is a good bit less than 20.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #4 of 8 (permalink) Old 09-03-2012, 11:37 PM
Yes, I said 5W-40. I don't live in Phoenix. Mornings here are now around 50 degrees and I want good oil flow at start up. As it warms, the polymers expand, thickening the oil as the engine parts expand. The lighter oil makes the starter's job easier too. No more noise than when 20W is in her.
RICZ is online now
post #5 of 8 (permalink) Old 09-04-2012, 07:12 AM
handyhoward's Avatar
There are soooo many riders out there who do not understand what the different weights mean in a multi-viscosity oil... you do and I do and a few others do, but not many. We will continue to use T6 and save wear and tear on the internal parts of our engines at start up.
Since the victory is air/oil cooled it does not require 50w as does the HD air only (even with an added oil cooler). The flow pattern of the cooled oil is the difference between the two... in the HD the oil just flows back to oil reserve and mixes with what's there... in the V the oil flows thru the cylynder walls on its way back to the reserve, thus cooling the engine on its way.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #6 of 8 (permalink) Old 09-04-2012, 09:26 AM Thread Starter
NJ8BALL's Avatar
I just hit my brothers supplier I can get amsoil for under 9 a quart, royal purple cheaper and Lucas even cheaper. I've used Lucas b4
NJ8BALL is offline
post #7 of 8 (permalink) Old 09-04-2012, 10:56 AM
There are additional benefits to using oils formulated for Diesel engines. Since Diesels run at much higher compression ratios, about twice that of gas engines, internal parts take a greater beating, so their oils have a greater amount of additives designed to protect those parts. For that reason, I use Diesel formulated oil in my 14 year old service truck (bought new) that has had no problems connected with lubing, or any others for that matter. I can't help but think that those same additives help protect my Vic's engine and that's why Rotella T6 has a JASO MA rating. Which means its good for wet clutches, among other things.
RICZ is online now
post #8 of 8 (permalink) Old 09-04-2012, 01:34 PM
Send a message via Yahoo to SteveYacht
Have been using Rotella 5w-40 in my 28 year old Honda with tens of thousands of miles on it for a long time...... actually quieter with the Rotella.
I don't quite get the reasoning behind your initial post then your follow up about pricing on Amsoil, Lucas and Royal Purple. Makes no sense.
Charter Life Member AMA
Life Member NRA
Member Legion Riders
U.S. Army Veteran
1968 Honda CB350
1973 Norton 750 Commando
1978 Suzuki 1000
1984 Honda VF700S Sabre
1985 Honda Gold Wing Aspencade
2013 Victory Cross Country
SteveYacht is offline
