Oil spec question - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 08-08-2015, 11:21 AM Thread Starter
Default Oil spec question
After completing my ride to Fort Lauderdale earlier this summer I decided I am changing the oil to 20/50 full synthetic.
My question: Victory spec calls for JASO-MA. The motorcycle oils I am seeing have specs of JASO-MA-2. Is there any reason not to use an oil that is "MA-2" vs. "MA"
My thought is that it is only a newer blend of the oil and should have no adverse affects.
Any comments would be appreciated.
thanks
Gary
Gary
2014 Cross Country Tour, Sonic Blue
Vance and Hines Hi-Output
43 0f 48 states on 2 wheels
Forked River, NJ
N17gary is offline
post #2 of 5 (permalink) Old 08-08-2015, 11:32 AM
JASO-MA2 is superior in some way to JASO-MA but I can't recall. It was posted recently in another oil thread. Both are fine for Vics. MA means it OK for wet clutches like ours. Seeing as you are in NJ, where you might want to ride in colder weather, why not consider Rotella-T6 full syn for easier start ups with its 5W base? That's the route many here, including myself have gone.
Seeings as you are Jersey Boy, click on this....https://www.youtube.com/embed/X_jNT3vJai0?rel=0
post #3 of 5 (permalink) Old 08-08-2015, 05:35 PM
From what I've seen, JASO-MA2 is the same as JASO-MA with the exception that it's safe for catalytic converters.
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #4 of 5 (permalink) Old 08-08-2015, 08:37 PM
vindex1963's Avatar
That's it.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 5 (permalink) Old 08-08-2015, 08:46 PM
Thanks Broggy.
