oil try out - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By rock54
post #1 of 4 (permalink) Old 08-12-2015, 07:20 PM Thread Starter
Default oil try out
has anyone tryd out the pensoil oil brand in their bikes...
any like or dislike....
thanks russ
rock54 is offline
post #2 of 4 (permalink) Old 08-12-2015, 08:02 PM
vindex1963's Avatar
If it's car oil you just made a mistake friction modifiers and wet clutches don't go together.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 4 (permalink) Old 08-13-2015, 03:33 PM Thread Starter
no didnt do anythin, guys at work are big pensoil fans, they didnt know
if they made it for bikes.....so i came to you guys to ask, russ
vindex1963 likes this.
rock54 is offline
post #4 of 4 (permalink) Old 08-13-2015, 09:11 PM
Default pennzoil motorcycle oils
looking at the amsoil white papers edition II from 2009 pennzoil motor cycle oils did poorly!! today pennzoil is using oil produced from GTL technology + "looks" to be a good product. its classified as "synthetic" + is a group III highly refined dino oil, shell products are beginning to use these base oils as well. if any of this better base oil gets into the motorcycle products time will tell, + it will be classified as semi or full synthetic if it does.
rodhotter is offline
