Front right hand side shock seal leaking. - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 09-08-2015, 11:31 AM Thread Starter
gmaxx's Avatar
Default Front right hand side shock seal leaking.
Has anyone had the seal on their front shocks develop a leakage? I have the Victory extended warranty. Would a seal replacement be covered under the extended warranty. If not what's the general ballpark part and labor cost out of pocket for something like this?
Oh, just over 41k mile on a 2013 XCT.
Thx!
Gmaxx
2013 XCT
Lloydz Air Filter
Ness Big Honkers Pipes
gmaxx is offline
post #2 of 10 (permalink) Old 09-08-2015, 11:45 AM
41k ain't bad for a fork seal. I would bet cash money that the extended warranty won't cover it because they are considered 'wear items'.
post #3 of 10 (permalink) Old 09-08-2015, 11:50 AM Thread Starter
gmaxx's Avatar
Thx! for the reply. So, is something to be expected at some point on the Vic's?
Gmaxx
2013 XCT
Lloydz Air Filter
gmaxx is offline
post #4 of 10 (permalink) Old 09-08-2015, 12:09 PM
roadcouch's Avatar
Mine started leaking AFTER the 15k fork oil service, I used the sealmate tool and it hasn't leaked in 6-7 thousand miles. I admit I had my doubts on this but now a believer.
roadcouch is offline
post #5 of 10 (permalink) Old 09-08-2015, 03:03 PM
DillPickle311's Avatar
This actually worked on mine.
DillPickle311 is offline
post #6 of 10 (permalink) Old 09-09-2015, 12:49 AM
BP6666VR's Avatar
Mine started leaking at 10k kilometers and made a sealmate too, forum members showed me how, but for 6 months it is leaking BAD so i ordered new seals
Cross Country Tour 2014 [B]
BP6666VR is offline
post #7 of 10 (permalink) Old 09-09-2015, 07:52 AM
Motorbikerx's Avatar
Yeah make up your own or buy a Sealmate, and BP6666VR ya gotta use it more than once, I clean mine out whenever they start gunking up with bug smegma and I notice fork oil dribbling down the back of my fork legs....just pop the dust covers then slip yr sealmate in..round and round a coupla times then jag the crap out, do it again then pump the front up n down clean the forktubes with a cl;ean rag, pump again and watch the seals reseal themselves...mine need doing every few months.
Not a problem....I carry my homemade sealmate in my tool roll.
Dont go buying seals till youve tried the zero cost solution!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 10 (permalink) Old 09-09-2015, 10:51 AM
bug smegma
yep! down-under bugs eat some gross stuff I bet.
I've seen some stuff on my shield that was super runny and that stuff going down into your forks will harden and allow your fork oil to seep out.
post #9 of 10 (permalink) Old 09-09-2015, 11:12 AM
buy seal mate and see if it fixs your leak
post #10 of 10 (permalink) Old 09-10-2015, 06:53 AM
Amazon.com: Motion Pro Seal Mate Fork Seal Cleaner: Automotive
or if youre handy with scissors and have an empty plastic milk bottle,
you could cut one out yourself, just copy the shape from the sealmate advert...easy-peasy
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
