2016 oil debate - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 24 (permalink) Old 01-04-2016, 01:34 PM Thread Starter
DillPickle311's Avatar
Default 2016 oil debate
Wait! Should have said Ďoil rebateí. Sorry!
I am really impressed with the efforts that go into producing oil and how we all need to get a good understanding of the importance in choosing what is right for our bikes and when we need to change the oil. I run T6 and trying to run at least 5000 before changing.
The following from...
Motorcycle Oil: What Difference Does it Make? - Motorcycle & Powersports News
______________
The finished product that goes in a bike is amber or brownish in color, base oils are actually clear, like water. Their quality determines a number of key performance properties, including oxidative stability (the ability to resist chemical breakdown), heat resistance, viscosity retention (the ability to resist thinning) and pour point (fluidity at low temperatures). The goal in manufacturing base oils is a molecularly uniform, pure substance. Why? Because inconsistency and impurities limit performance. Additives in the final motor oil formulation offer specific performance features not provided by base oils, like the ability to resist corrosion that may form when bikes are in storage.
The base oils used in conventional oils are anything but uniform and pure. They are refined from crude oil pumped from within the earth, which is a poor lubricant in and of itself; itís a thick, messy, foul-smelling raw material teeming with molecules of different weights. Sulfur, paraffin (wax), nitrogen, oxygen and nickel are just some of the molecules in crude harmful to the lubricating process. Paraffin, for example, thickens as the temperature drops, making it more difficult to start your motorcycle on a cold morning and inhibiting the oilís ability to quickly flow to critical engine parts. Itís no coincidence the majority of engine wear occurs at start up. Impurities cause the oil to oxidize sooner ó in laymanís terms, break down ó requiring it to be changed. Thatís just one reason conventional oils reach the end of their useful service lives sooner than synthetics.
DillPickle311 is offline
post #2 of 24 (permalink) Old 01-04-2016, 01:35 PM Thread Starter
Just so you'll understand, I'm not pushing any particular brand... you choose what you like and do your own research.
post #3 of 24 (permalink) Old 01-04-2016, 01:49 PM
Richie271's Avatar
______________
WISE GUY! You got me.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #4 of 24 (permalink) Old 01-04-2016, 02:21 PM
BlueVegas's Avatar
Good read. I'm an Amsoil guy myself.
BlueVegas is offline
post #5 of 24 (permalink) Old 01-04-2016, 02:51 PM Thread Starter
Walmart has Shell T6 2 gallon @ $21. It takes 6 qts in my 04 Vegas.
I live 1/2 mile from wallymart and 1 mile from O'Reillys where I get the wix filter.
Price, convenience, and the time it takes to get the products is a plus and then to get the mileage and performance from this brand is, what I feel, a no-brainer.
post #6 of 24 (permalink) Old 01-04-2016, 02:53 PM
Honda East Toledo's Avatar
I just sell em all.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #7 of 24 (permalink) Old 01-04-2016, 03:01 PM
vindex1963's Avatar
Originally Posted by Honda East Toledo View Post
I just sell em all.
Best answer I've seen in years!!!
theja1 likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #8 of 24 (permalink) Old 01-04-2016, 03:21 PM
Correction, All but Shell, the Citgo/Autozone/wally/speedway sells that.
(877)-437-1631
Like us on Facebook
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
post #9 of 24 (permalink) Old 01-04-2016, 05:44 PM
Motorbikerx's Avatar
I was hoping for another debate!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 24 (permalink) Old 01-04-2016, 05:56 PM Thread Starter
Use regular dino motorcycle oil for your bike and change it and filter every 3000 miles and it will last you a long time and perform well.
Use good synth oil and change every 4-5000 miles and it will last you a long time and perform well.
Which is the best option.
