rotella t6-5w-40 syn - Victory Forums - Victory Motorcycle Forum
post #1 of 91 (permalink) Old 02-21-2013, 05:55 PM Thread Starter
Default rotella t6-5w-40 syn
how many are using this and are there any uoa's for this stright up
2012 CC red and silver
lloyds cams
idle air
pcv
adjustable timing gear
lloyds air filter
d&d slip ons
1/4 turn throttle ring
txcanvasback is offline
post #2 of 91 (permalink) Old 02-21-2013, 06:45 PM
Lostintexas's Avatar
Well, I do not know who "Wisdom" is, so we get that out in the open.
I have used T-6 in the last 3 rides with close to 350K on them combined without a hitch. They were water cooled and NO, Victory didn't invent the wet clutch or the combined use of engine/trans use.
Now for the "Wisdom" part. This is my first twin and first air cooled engine in a very long time. "Wisdom" says, or at least used to, theat an air or air/oil cooled engine needs thicker oil. I don't know why or how true it is.
I'm running the T 15W-40 in my XCT right now and have all the complaints I ever had with Rotella---None!
Here is a little reading for you with the UOA.
https://www.victoryforums.com/showthr...hlight=Rotella
Read through this, the gent that started it has gone to the T-6.
A little deeper.
https://www.victoryforums.com/forumdisplay.php?f=25
I hope the links work
Cheers
I ride with the Force.
Lostintexas is offline
post #3 of 91 (permalink) Old 02-21-2013, 08:06 PM
Been using T6 since the first oil change. No problems at all. Shifts great and good clutch action. The wife and I can have a nice dinner out with what I save as opposed to the cost of the Vic kit. Its JASO-MA rated, which means its approved for motorcycles with wet clutches. Go for it!
post #4 of 91 (permalink) Old 02-21-2013, 08:57 PM
Tarzan's Avatar
I mix T6 and regular Rotella.
'14 Ness XC
Tarzan is offline
post #5 of 91 (permalink) Old 02-22-2013, 02:20 AM
saintdruss13's Avatar
I don't know why people get so worked up over oil threads they are usually good for a few laughs.
I just switched to T-6 for the first time so for no problems, I also rub mule deer semen on my chest before each ride don't know if it helps but it makes me feel better.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
post #6 of 91 (permalink) Old 02-22-2013, 04:39 AM
Pop
Bet the mule deer has good things to say about you too.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #7 of 91 (permalink) Old 02-22-2013, 06:47 AM
handyhoward's Avatar
I have used Shell Oil's T-6 5wt-40 since its inception in my Fatboy, my Goldwing, and my Vision... works great.
PS... @ LostinTexas... there's no up side to 15wt-40 over 5wt-40... it behaves the same at operating temperatures. The upside to 5wt-40 is better lubrication at start-up.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #8 of 91 (permalink) Old 02-22-2013, 10:06 AM
How many bucks does that cost ya?
post #9 of 91 (permalink) Old 02-22-2013, 10:57 AM
The only thing that I would caution about the 5w at start-up is that it could cause your lifters to bled down and make some noise. Also, it doesn't lubricate better when cold because it's to thin, which could cause additional wear at start-up. If you don't put that many miles on your bike then a lot of things won't matter. Use what you want.
2012 Vision Tour
Oklahoma City, Ok.
atom bomb mod
ATS +4
A-dog is offline
post #10 of 91 (permalink) Old 02-22-2013, 11:06 AM
T6 is blended for use in Diesel engines which are a lot harder on their oil than spark ignition ones. Some of the additives in engine oils, and especially those for Diesels, are there to coat parts so there will not be a dry start up.
