Trouble with oil change - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 02-25-2013, 08:37 PM Thread Starter
Default Trouble with oil change
So, it is time to do my first oil change on my XCT and I am having no luck getting the drain plug out. The bike was a demo and the dealership did a change just before I got the bike and at the 500 mile break in recommendation. I'm calling the dealer tomorrow but to get there requires a loss of time at work or hoping to get a spot on the odd Saturday. It took more then the 15ft lbs and I got nothing.
Ideas?
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #2 of 14 (permalink) Old 02-25-2013, 08:52 PM
Tims_04V92TC's Avatar
It may take more than 15 foot pounds to get it out, just ensure you have a GOOD hex in it, good solid leverage and crank it counter clockwise. Should hear a nice pop when it breakes loose because the crush gasket does its job. Number one complaint on oil plugs loosening up after service I am told is DIY that reuse the old gasket like our cars. ensure you ALWAYS toss that old gasket.
Hope this helps.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #3 of 14 (permalink) Old 02-25-2013, 09:14 PM
rainman123's Avatar
also make sure the engine is warm it will sometime help loosen the bolt
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #4 of 14 (permalink) Old 02-26-2013, 08:14 AM
handyhoward's Avatar
Warm engine... and you can use a propane torch to heat the bolt a bit also. Make sure it is the correct bolt... and there doesn't need to be that much torque on it when the copper crush washer is used... copper is a soft metal and crushes very easily and makes for a great seal.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #5 of 14 (permalink) Old 02-26-2013, 08:26 AM
+1 on that. Have not had a single leaker nor problem removing when torqued
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #6 of 14 (permalink) Old 02-26-2013, 11:11 AM
Do Not Use Heat. Heat will make the metal expand.
If you can't get it loose ride to dealer and ask them to loosen it. That way if there is a problem its theres for over tightening it.
post #7 of 14 (permalink) Old 02-26-2013, 11:18 AM
Luciferiad's Avatar
+1 on warming the bike up. It also helps the oil flow more easily so you won't have to wait quite as long
Also, I'm not saying this to be snarky or anything. I've been in the auto service biz for a long time, and I still find myself making this mistake. Make sure you're not accidentally turning the plug the wrong direction. Righty tight-lefty loosey only works when the bolt-head is facing you. lol maybe I'm not that good a grease monkey if my brain doesn't automatically compensate for the plug being upside down from my orientation.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #8 of 14 (permalink) Old 02-26-2013, 11:56 AM
get the moter hot as some have said. it should be for a change anyway. don't heat the plug, it will expand it making it tighter, that only works for nuts on the outside of a bolt.
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #9 of 14 (permalink) Old 02-26-2013, 12:50 PM Thread Starter
I picked up a hex socket today to try. I was using a good quality key with a socket and extension on the end and had at least a 30* deflection on the key arm and nothing.
I also can get lefty/righty turned around at times. After an oops that cost many hours I visualize and then tripple check.
We'll see what I can do tonight with better tool. The dealership says that they have had trouble cracking them loose at times.
ChuglyXJ is offline
post #10 of 14 (permalink) Old 02-26-2013, 01:41 PM
Cool Blue's Avatar
One thing that works for me when it is real tight like that is so put the hex key in and hit the handle with a rubber mallet carefully to get it started. Use care not to strip the bolt. Make sure the key fits tight.
Cool Blue is offline
