Overtightened the oil drain plug - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 07-16-2013, 03:04 PM Thread Starter
Default Overtightened the oil drain plug
First time I changed the oil in my '01 V92 and I overtightened the plug and bent the metal rim that holds the rubber bushing/washer. What is the best solution and if I need to buy a new plug where can i get it?
ffisk7891 is offline
post #2 of 2 (permalink) Old 07-16-2013, 08:02 PM
ByteN2it's Avatar
You can pick up a replacement at Ace Hardware, or probably any auto parts place along with a fiber washer will keep you going. I'm pretty sure the size is M12x1.75, it would be best to match your old one up as I could be wrong on the size-maybe it was 12 x 1.5?
ByteN2it is offline
