Victory brand oil - Victory Forums - Victory Motorcycle Forum
post #1 of 153 (permalink) Old 01-23-2014, 06:18 AM Thread Starter
Default Victory brand oil
There has been an ongoing debate about Victory brand oil. Seems there are those in the camp that say Victory sesigned this oil for the overhead cam engine that Victory designed.
Then there is the other camp who say hog wash and use other brands and weights of oil with no problems at all.
Well I think we can now put to bed the issue about Victory brand oil was designed solely for the design of the Victory engines. Seems that Polaris is using the same 20-40 oil in the new push rod Indian engines with the only change being the labeling on the bottles being Indian instead of Victory.
This pretty much confirms that Polaris' choice to use 20w-40 is an attempt to lock in sales of their over priced group 2 semi synthetic oil. Remember group 3 oils can be labeled as full synthetic per the courts. After all there are very few oils offered in the 20w-40 spec so you more than likely have to buy Victory oil it you insist on running their 20w-40 spec.
The Indian and Victory engines could not be any more different from each other. One is a push rod engine the other an overhead cam engine. They both produce power differently within the RPM ranges.
Even Yamaha has dropped their 20W-40 oil and went with 20w-50 as their spec now.
The debate is over, use any brand you want from 10w-40 to 20w-50.
Victory 1 is offline
post #2 of 153 (permalink) Old 01-23-2014, 06:27 AM
vindex1963's Avatar
You have to be a paying member to start a thread like this didn't you read the rules. Starting a thread just for arguments sake is strictly for paying members.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 153 (permalink) Old 01-23-2014, 06:40 AM
Default How about warrenty work?
I use Victory oil just because as funny as they are about repairs I don't ever want them to throw this in my face.
Would they be able to tell what brand oil is in it?
I would like to try the Rotello
2013 HIGH BALL
heddonbaits is offline
post #4 of 153 (permalink) Old 01-23-2014, 03:18 PM
Krisd's Avatar
hahaha.....
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
post #5 of 153 (permalink) Old 01-23-2014, 03:45 PM
Pckrfan's Avatar
Seems Polaris is using the same 20-40 oil in the Indian? Can you please provide proof other than the all encompassing words "it seems".
2013 AG-XC:
Gustafsson +2 Euro Flip
JWSpeaker 8695 LED Headlight
Ma Vic (Black Tri-Ovals/S1 Package, pull backs, derby covers,
heated seat, bag bars, shorty antennae)
Ness Rad III mirrors, Avon heated grips, Wolo Bad Boy air horn
RICZ's LD PL8 bracket and lotsa blacked out stuff
GOODY'S fork mounted lowers (3M'd)
Bag graphics & inner fairing, Bad Boys Design Peoria, AZ.
Artificial intelligence is absolutely 100% NO MATCH...............for natural stupidity!
Pckrfan is offline
post #6 of 153 (permalink) Old 01-23-2014, 04:12 PM
SilvrT's Avatar
IMO, as long as the oil you use meets or exceeds the manufacturers recommendation (Victory in this case), how can they "throw it in your face"? I doubt there is any law in the land that states "if you ride a Victory, you MUST use THEIR OIL".
The concern would be more to proving you've changed the oil at the recommended intervals.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #7 of 153 (permalink) Old 01-23-2014, 04:19 PM
Pckrfan's Avatar
I had a long conversation about using other brands in the Vic engine with customer service in Minnesota. The guy made it very clear to me that should an engine implode or suffer some catastrophic failure while under warranty, they will do an oil analysis to see if it played a part in the failure. If it is an oil other than Ma Vic's lubricating elixir, then the customer is hooped if a determination is made the oil contributed to what it was that blew the motor up. So in my mind, while it's still under warranty, I'll be happy to use the company elixir to keep the motor running. I don't have deep pockets to file suit if I disagree with their findings.
2013 AG-XC:
Pckrfan is offline
post #8 of 153 (permalink) Old 01-23-2014, 04:19 PM
CrossRoads's Avatar
Lloydz words (without the use of "it seems"):
"I get asked this ALL the time. Which oil do I recommend in a Victory? My answer is Victory 20w40 oil! I don’t care about your oil analysts, I don’t care to hear your primary sounds quieter, I don’t care to hear the other oil you use is cheaper, I don’t care to hear any other comment you have about another oil. Cause and effect, you may have caused one thing to “get better” but you just affected another to get worse. I see HUNDREDS of torn apart motors every year, I can with a great deal of accuracy tell which oil was in that motor. It’s not a super power I possess; certain oils leave characteristic stains, marking, smell and wear in different areas of the motor. I’m by all means not experienced in all oils in these bikes but there are the top 4 used that I’m experienced with.
Now I will also say, I’m not suggestion Victory oil is by far the best oil in the world for these bikes. I am saying, with the ones that are typically used Victory oil lends itself to be the superior oil for wear and parts protection that provides a manageable and stable temperatures.
One issue raised is this, if there is better oil, let’s say Royal Purple. It’s oil I’ve wanted to try for years. It would take me an unknown amount of years gathering information to sit down and recommend another brand. Conclusions can’t be made on 1 engine, that’s bit me in the ass before.
So what’s my ending statement?
If you have the ability to buy Victory oil, IMO there’s no reason to open the top on another brand."
CrossRoads is offline
post #9 of 153 (permalink) Old 01-23-2014, 04:25 PM
vindex1963's Avatar
I love oil threads especially when the resident part time troll starts them and now that I've said troll he'll break the rules and start another username.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #10 of 153 (permalink) Old 01-23-2014, 04:27 PM
Krisd's Avatar
(continued from above).....hahaha.....
2012 Hammer S
Krisd is offline
