K&N oil filter #KN-198 - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 01-26-2014, 01:53 PM Thread Starter
72XS2's Avatar
Default K&N oil filter #KN-198
Hi, I did a search on the forum and didn't find my answer so sorry if this has already been discussed before. I'll do my second oil change on my Hammer soon and I would like to have some inputs from K&N oil filter users here. I want to know if the tickling noise at the start-up is quieter. They are build with an anti drain back valve so I guess that it should be better at start-up because the oil don't return completely at the base of the engine. I always used them on my cars and bikes before without any problems. I first tried K&N on a Chevy V6 3,4L and it really helped with the valve noise at start-up due to the hydraulic lifters, especially during winter so I'm curious to know if they can do the same on a Victory engine. Thanks !
72XS2 is offline
post #2 of 13 (permalink) Old 01-26-2014, 02:35 PM
lunaticrider's Avatar
The K&N filter is just a Hiflo filter with a $8 nut welded to the end of it. Not a terrible filter just not as good as the eaOm103 Amsoil nanofiber filter or a Wix...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 13 (permalink) Old 01-26-2014, 05:43 PM
80% of the guys use a WIX filter and oil filters will not change the ticking noise on start up. The lefters bleed down when you shut the bike off and when you start the bike they pump back up. Wix p/n 51356
post #4 of 13 (permalink) Old 01-26-2014, 06:10 PM Thread Starter
72XS2's Avatar
I know that lifters bleed down when you shut the engine off with any model of filters but K&N have an anti drain back valve in them and my question was if people who tried them have seen a difference or not on their bikes. What's the main raison of using WIX filter instead of the one from Victory ?
2014 Victory Cross Road 8 Ball
2 - 1972 Yamaha XS650
From Chute-aux-Outardes, Quebec, Canada
72XS2 is offline
post #5 of 13 (permalink) Old 01-27-2014, 09:46 AM
Motorbikerx's Avatar
I'd hazard a guess that its price
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 13 (permalink) Old 01-27-2014, 10:24 AM
Most good filters have the anti drain back valve, personally I wouldn't take a K&N over an Amsoil nanofiber filter (drain back valve) or a Wix (in that order) ....
post #7 of 13 (permalink) Old 01-27-2014, 10:27 AM
vindex1963's Avatar
Mobil 1 M110
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #8 of 13 (permalink) Old 01-27-2014, 10:49 AM
slickvic's Avatar
Using Vic oil change kit n a box? Stick with the filter that it comes with. Changing oil to another brand? Use Wix as mentioned. Thinking about Amsoil? Use Amsoil's recommended filter.
I use Amsoil and there filter with great results.
slickvic is offline
post #9 of 13 (permalink) Old 01-27-2014, 11:49 AM
Wix you can get at any auto parts store for $6.99 and they make filters for NAPA and others
post #10 of 13 (permalink) Old 01-27-2014, 01:23 PM
Default quick flow = REAL synthetic oil
Amsoil may help, what's Vics 20-40 pour point? amsoil 10-40 is -51F better for cooler weather, their 20-50 pours at -40F. there are lots more benefits as well. i can not understand why anyone would run overpriced underperforming oil in their expensive victory engines, mobil I is another option as well. oh about the filter Wix who makes Vics filter is an excellent filter better than K+N from the tests i seen, amsoil's may be even better at a higher cost.
rodhotter is offline
