Vic oil better heat transfer? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 08-27-2011, 07:30 AM Thread Starter
Default Vic oil better heat transfer?
I bought my V92sc used and have always used Rotella since I bought it. During the high heat recently I switched to Vic oil. I have noticed the bike seems quieter. the other thing is it seems to radiate more heat. My thinking is that the vic oil is better at transferring more heat through the cooling fins of the jugs. I noticed this because outside temps have dropped but there seems to be more heat coming from engine. I don't know maybe it is all in my head. no there are no exhaust leaks no my riding style has not changed. Only thing changed is the oil and outside temps. Just an observation and wonder if anyone else has noticed this. Also this is all seat of the pants no hard measurements.
Bill
mrbill65 is offline
post #2 of 12 (permalink) Old 08-27-2011, 07:51 AM
Bad V V's Avatar
Yeah if read the other countless oil threads you'll see that's what victory always claims. You can even go on YouTube and watch videos made by victory about how much better their oil when it comes to cooling the engine.
2003 Victory vegas
Bad V V is offline
post #3 of 12 (permalink) Old 08-29-2011, 08:07 PM
Kuchera89's Avatar
or the motor is actually running hotter and radiates more heat as a result, that'd make more sense to me. this whole "victory oil carries heat and dumps it in the oil cooler better"...not sure im buying it.
im happy to say the shop i work at just got set up with amsoil and i will be trying it soon.
2007 Hammer S 100CI
S&S air cleaner, PCIII, SRVT clubs exhaust, Avon grips.
2006 Kingpin 100CI
stage 1, touring setup to come soon...nm bought a XC.
2013 Sunset red and black XC
Kuchera89 is offline
post #4 of 12 (permalink) Old 11-16-2011, 05:33 AM
Default Re:
I think we are getting a little too scientific here...
The coolant temperature is controlled by the thermostat, if something makes the engine run cooler,or hotter,the thermostat will adjust to keep the temp at the prescribed level.
Mighell.connor is offline
post #5 of 12 (permalink) Old 11-16-2011, 06:14 AM
Tarzan's Avatar
Actually, there is no thermostat or coolant on an air cooled motor. But I'm sure you know that right? You just teasing us?
'14 Ness XC
Tarzan is offline
post #6 of 12 (permalink) Old 11-16-2011, 01:44 PM
You said its cooler now where ever you live and you feel the heat from the motor.
Now if its cooler out don't you think you would feel the heat as appose to when its warmer out.
If your legs are cold you would feel any kind of warmth
post #7 of 12 (permalink) Old 11-16-2011, 02:58 PM
06vitory's Avatar
Does any one have any idea whos oil is in the Victory bottles?
2006 Kingpin Deluxe
Stage 1 pipes
Dunlop D407 & D408 tires
06vitory is offline
post #8 of 12 (permalink) Old 11-17-2011, 02:23 PM
wesdalton's Avatar
Olive oil in the Vic bottle
Snake oil in the scamsoil bottle
(just kidding of course) but then it is another oil thread
2010 X C
wesdalton is offline
post #9 of 12 (permalink) Old 11-18-2011, 12:19 PM
All of Polaris oil come from Lube Tech
http://lubetech.com/
post #10 of 12 (permalink) Old 11-19-2011, 09:20 AM
DTWOR's Avatar
Depends on which air cooled motor.HD oil cooler has a 190 +/- deg. bypass so oil doesn't flow through cooler until oil's some where around operating temp.Most aftermarket coolers have a thermostst option also.
2011 Pearl White Vision
IBA #47523
DTWOR is offline
