Moo! - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 03-29-2014, 02:49 PM Thread Starter
irv
irv's Avatar
Default Moo!
im gonna try to follow one of the herds here. for all
the almost 14000 miles on the bike its had vic oil. now has 5-40 T6 rotella. quess we'll find out what happens. ive still got 3 gals of
vic oil left. sunny and 50 today. have to put a couple of miles on it.
ive got the flatbed [ ph #]in my cell phone[yeah, it fits .
to be continued---
mph faster].
irv is offline
post #2 of 9 (permalink) Old 03-29-2014, 05:46 PM
10w40 is way better then 5/40
post #3 of 9 (permalink) Old 03-29-2014, 05:54 PM
dtmmil's Avatar
Sorry i disagree, what difference does the 5 and 10 make? None one it warms up a little, 5 will let it spin faster and allow oil to get everywhere faster.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #4 of 9 (permalink) Old 03-29-2014, 08:16 PM Thread Starter
irv
irv's Avatar
if they made a 10-40 T6 it would probably be in there
mph faster].
irv is offline
post #5 of 9 (permalink) Old 03-29-2014, 08:21 PM
dtmmil's Avatar
If you do some searching vindex i believe had some testing done on his oil and came up with a mix of rotella 15-40 and 5-40 that seemed to test well.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 9 (permalink) Old 03-30-2014, 12:02 AM
ammo_umb's Avatar
I started with Vic oil and changed to Amsoil for the next two changes. After that I used Rotella 10/40 for two changes and have used 3 qts of Rotella topped off with 20/50 Mobil motorcycle oil for the last 3 changes. So far the Rotella/Mobil blend works best for me with the big temperature swings I deal with riding year round.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #7 of 9 (permalink) Old 03-30-2014, 12:18 AM
vindex1963's Avatar
Four quarts Rotella T 15-40 two quarts Rotella T6 5-40. My 04 has a six quart capacity. I can say the 40 wt is what you're looking for the first number is "W" winter.
Mine sees upper 30s to 120* as tested and looks good.
I recommend nothing use what makes you feel all warm and fuzzy.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #8 of 9 (permalink) Old 03-30-2014, 01:17 AM
Motorbikerx's Avatar
well after 3500 kilometers on Aussie Penrite 10-50 MC semi-synth, plus 250ml Lucas oil stabiliser to top it off, my 2010 Vegas 100/6 is going fantastic, gearbox shifts better, zero clutch slip (it's JASO-MA after all)
I'm sticking with it for the Aussie climate.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 9 (permalink) Old 03-30-2014, 06:44 AM
handyhoward's Avatar
At operating temperature there is no difference in "performance" between a 5-40W or a 10-40W or for that matter a straight 40W.
The lower viscosity, or first number in a multi-viscosity oil is it's "performance" at start up or less than operating temperature.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
